37" Genesis Build
  • dddmx3
    • Mar 2010
    • 233
    37" Genesis Build
    Looking to build a 37" Genesis. Bought the hull and hardware. Stuck on the electronics.
    Thinking of going with 2x Leopard 4550kv Brushless Inrunners with a swordfish 200+ esc and 4s lipo 5000mah 25C to each one. Let me know if I have any problems with my planned setup.
    After all is said and done, more is said than done.
  • h2o 1
    • Sep 2011
    • 770
    Thats over 67,000 rpm's,problem isnt the word! Catastrophic failure is more like it!!
    • dddmx3
      • Mar 2010
      • 233
      What should I do to fix my setup?
      • h2o 1
        • Sep 2011
        • 770
        Youre good on the esc,you may want to get higher c rated batts also. For 4s go with a lower kv, around 1800 to 2200 kv.You may also want a longer can motor
        • dddmx3
          • Mar 2010
          • 233
          How about this inrunner 2200kv 70mm inrunner with these lipos?
          • h2o 1
            • Sep 2011
            • 770
            NICE !!! That would make that Genesis scream!!
            • dddmx3
              • Mar 2010
              • 233
              Thanks. Will update with pictures while installing.
              • h2o 1
                • Sep 2011
                • 770
                Always start small with ur props and check your temps often during the break in period. Goodluck with your build!
                • dddmx3
                  • Mar 2010
                  • 233
                  What size props do you recommend?
                  Also... should I make both props spin clockwise? Or make the left one spin counter clockwise (reversed prop) and the right one clockwise (normal prop)? It seems kinda like a smart idea..
                  • h2o 1
                    • Sep 2011
                    • 770
                    Octura x442 is where i would start with props. Counter rotating on the props.
                    • dddmx3
                      • Mar 2010
                      • 233
                      Thanks.
                      Bigger props = more speed, less run time because of more work
                      Smaller props = less speed, more run time because of less work
                      right?
                      Is that what it is called? Counter rotating? Also, what do you think of the cnc props?
                      • h2o 1
                        • Sep 2011
                        • 770
                        Personaly im a fan of the smaller props and high rpm's! Cant tell you too much about the paddle wheels.Correct,its called counter rotating.They can turn both inward or outward. I like the CNC props, that what i have on my Daytona/ Genesis.
                        • dddmx3
                          • Mar 2010
                          • 233
                          Ok. So pretty much I just have to buy a bunch of plastic props and once I find a set I like, buy cnc ones?
                          • h2o 1
                            • Sep 2011
                            • 770
                            Its a good idea to start with the Composite props if you can find them in l/r configuration.
                            • dddmx3
                              • Mar 2010
                              • 233
                              Ok. I'll find out what I like and then buy the same set but cnc version. Thanks for your help
