Spirit of Texas Drag Hydro
Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @ -
In relation with the corner..Which prop would be affected by disturbed waterflow...? inside or outside?? ive heard both arguments, both make sense... but which is really the lesser of two evils?
Drag and aerated water from propblast on rudder....
Or disturbed waterflow (from rudder) to prop???
If it's the inside prop thats affected, Wouldnt this disturbed waterflow cause the undistubed prop to have more thrust than the prop IN the disturbed water?? Causing the boat to turn better/faster???
Good job with the temp cowl doc. :-)Im confused..... no...wait...mabee im not?Comment
Good job with the temp cowl doc. :-)Comment
Took the beasty out today for its' maiden, using the temp cowl.
Woohoo !
slight water ingress up the shaft outers , couple tablespoon's worth, absorbed by strategically placed paper towel.
It floats on a cushion of air at 65mph+, and has positive buoyancy !
hopefully Richie and/or Wade will post video soon
IME the inside of corner motor returns warmer/hotterWayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
@ 36" H&M Maritmo twin1512/1800 6S1P 88mph @ 40" drag hydro#1 twin 5692 12S1P .....always for fun @Comment
Dont worry doc.. videos i took turned out great. I checked again........the first duck the boat "buzzed" definately crapped himself!! :-)
Think the fish got a bit of a fright too... He..he...he... bouyancy....CHECK!!!! HELL FUNNY MATE!!!!Im confused..... no...wait...mabee im not?Comment
65mph+
videos look a blast !
tore a M3 bolt from servo mount ! .. damn there's some forces here.
Have higher torque servo.. is possible the used has insufficient to turn against the twin thrust cones .. ?Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
It's possible. Try it. Had you thought about putting a longer narrower rudder on? Maybe short and wide isn't the best optionComment
The not so great turning could just have todo with the hull, if u think about it, the full scale drag boats have bloody TERRIBLE turning radius's!!!!Comment
here is the list of maybes
1. maybe rudder servo too weak ( 13Kg)
2. maybe thrust cones from both props, with rudder 1" behind, degrades steering due aeration/turbulation ?
2a. however the water pickups on rudder performed well, with outlets spraying2 foot to the side as it passed.
3. maybe needs a larger turn fin ( has 3x2" now )
4. maybe it's just overpowered ( eek, slap me quick ! )Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Doc.
Have you thought of reversing the props (& shafts) & motor direction so that the props turn in at the top instead of out. I know that one way is better than the other but I can't remember which.
Also, I know that it is a different kettle of fish, but the big twin riggers have the props spinning the same way or they just won't turn. Could it be the same with a twin V with the drives close together?See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
The rudder moveent induces yaw which turns the boat.
Rudder movement here did nothing.
Either the rudder did not move ( servo too weak ?) or the prop wash blew beyond that rudder movement.
I know the last 1.5" in is water, as the pickups work well, but above that.. perhaps those top 4" are all froth and bubbles ?Wayne Schutte PhdCSE BaSE BaEE. Australian, & damn proud of itYOUTUBE
Ya true!!! Ya do u have counter rotating props??? And if u have an extra servo laying around can't hurt to try that out!!!Comment
