This is turning out to be an interesting build... I made about 5 springers in different sizes (from standard to 5" long) and they are quite fun to drive. Just one recommendation: this hull does not like high rpm. 20000 on 50mm will make it jump out of the water, better go for the brushed motor or make sure you have a good quality ESC with low rpm control. Most of the Seaking/Hobbywing/Turnigy marine will be ok, the T180 in your pics should be perfect.
One more thing: I would try to use the Kort nozzle shaft for cooling. If you can change the shaft for a decent thickness tube, get it out in the kort a couple of mm and cut it at 45deg, you will get an excellent cooling.
