Im just not under standing why you have it shaped like an S.
Is that the proof that your engine mount is tilted way to far?
Or am i missing why you cant run the tube from where the coupler will
be at to the transom of the boat with just 1 long, smooth curve.
my engine mount is tillted far but it has to be like that and its an S becouse there is wood in the back compartment that i needed to go over.
Looks like you should have put in the stuffing tube before you put in all that wood back there.
it was bent becouse of the batteries that (might go there)and im keeping it bent like that just if i will put bats in the middle.
yup i should have but it should be fine right?
I thought you said you didnt mount the motor to far forward?
if the motor mount has to be bent down so the batteries fit.
Which is making you bend your stuffing tube crazy like, youve got a problem.
