MHZ Mystic 240 (94'') electric
Lol twisted I see all these post from u on everyone else's build threads throwing them on the main topic. I want to know have you ever built a boat or even own one.my youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
Hello
my settings on the hifei 300
Timing automatic, curent was same as with timing middle,but RPM was with automatic higher.
PWM 12Khz,at 8Khz the max RPM was to low.
Lipo cut off at the lowest setting which is possible.
The TP Motors are very good.
I run a smal 4060-1800 in a 1/5 2WD Offrad Car (FG Marder) with a Turnigy 180 Boat Esc and 3s2p Lipo with 10000 mah.
Car runs 22 minutes with a speed of 55 kmh (34 mph) without Problems.After the run esc and Motor is cold.
bye
mudlComment
Mudl,
I think your experience with the Hifei may have been different than mine due to the difference in motors. I ran two different 4 pole motors, and yours is 6 pole. I have had some issues with certain ESCs when running 6 pole motors. Some will not spin full RPM, and do not run smoothly at full RPM. I found on the FC (Flier) ESCs that if raising the PWM did not help, lowering the timing could sometimes mitigate the problem. One of the good things about those ESCs is the ability to raise and lower timing one degree at a time.
Thanks for sharing your build...the information you gain with these parts is very valuable for everyone and your boat is beautiful!Comment
I have 3 boats. smallest one is the zonda and is 42" it was my secound boat first boat is 54" long and is a mono hull. currently building a 56" cat. I hope this works for you.
The esc's are 280 amp the secound picture shows the anti-spark wires that the esc's come with.Last edited by twissted; 01-17-2013, 10:31 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
WOW Twisted, boat looks sick. Volvo s60 would work well for transporting larger boats. Looks like the Hifei escs are working well as two used schulz controllers showed up in the buy n sell section.Comment
