Darin's Vac-U-Pickle
  • andym
    More Go Than Show Prop Co
    • 2406
    #61
    Doug, my hydro should be in OZ soon where did that turn fin come from?
    • Doug Smock
      Moderator
      • 5272
      #62
      Ray Fuller, it's on his precision hardware page.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • andym
        • 2406
        #63
        Thanks Doug, did anyone try the solinger harware or did all the trial boats run fullers?
        • Doug Smock
          Moderator
          • 5272
          #64
          Your welcome,
          We used Fullers on all the prototypes. As far as I know flyguy55 has built the first one with Solinger hardware.
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Flyguy55
            • Jan 2008
            • 216
            #65
            I recived a PM on how the Solinger hardware set fits .
            The push rod doesent line up between the servo and rudder horn with out a z bend .
            The rudder horn sits on top of the rudder and is at least 1/4" too high and is too far left. Depending on what kind of push rod seal you use it takes a Z bend to line up. I also used a Heavy Duty EZ connector on the rudder connecton mounted below the horn .
            It looks like it will be fine.
            I mounted the bracket screws on the transom center line that offsets the strut 3/16th to the right. The strut is mounted on the left side of the bracket.
            • Flyguy55
              • Jan 2008
              • 216
              #66
              Solinger Hardware om Vac U Pickle
              • Flyguy55
                • Jan 2008
                • 216
                #67
                What A Pickle
                • TeamFubarRacing
                  • Jan 2008
                  • 45
                  #68
                  "What a Pickle"
                  very clean look to it Fly...
                  Ron
                  TeamFubarRacing, Winter Park, FL
                  • Flyguy55
                    • Jan 2008
                    • 216
                    #69
                    Interor Lay Out
                    • andym
                      • 2406
                      #70
                      It looks in the pics that the strut is not at 90deg to the hull, or is it an illusion? What motor ,esc and cells?
                      • Flyguy55
                        • Jan 2008
                        • 216
                        #71
                        A square says its 90 deg. Its off set to the right to offset propwalk.
                        The other specs are lisited in post # 56 .
                        • andym
                          • 2406
                          #72
                          A 6L should be interesting, what is the prop in the pics looks quite large for a 6L. I am glad the square says that strut is straight because it does not look like it in the pic!
                          • Flyguy55
                            • Jan 2008
                            • 216
                            #73
                            The prop is a new barstock 50mm 3 blade from Andy Brown , just for fun , Grin
                            An X438 is on it for tomorrows tests.
                            • andym
                              • 2406
                              #74
                              Can you post a vid? Would like to see how it goes on two cell compared to the 4s video I have seen. Cheers and good luck with it.
                              • Flyguy55
                                • Jan 2008
                                • 216
                                #75
                                No Video cam , and my test pond is very small . I won't learn too much tomorrow.
