Darin's Vac-U-Pickle
  • flyboy320
    • Mar 2008
    • 88
    #31
    Originally posted by Heath M
    the solinger hardware is probably the best choice for this size boat,very light and easy to install
    Heath
    Can the rudder arm be turned upside down and swapped to the other so the rudder is on the left side of the prop? Can't really tell by looking at a picture of it.
    The reason I ask is I see the boat is designed to have the rudder servo on the left side "Pre-drilled servo box in port rib made to fit a HiTec HS-225BB Mighty Mini Servo."
    EDIT: Well just found out on another board that it can be mounted on either side...
    • Doug Smock
      Moderator
      • 5264
      #32
      How long is that rudder?
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • flyboy320
        • Mar 2008
        • 88
        #33
        Doug
        From OSE web site,
        Rudder blade below the rudder bracket measures 3" x 1"
        • Doug Smock
          Moderator
          • 5264
          #34
          I'm afraid that rudder is too short. You need to go with a 3.5" rudder minimum.
          Doug
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • flyboy320
            • Mar 2008
            • 88
            #35
            I'm afraid that rudder is too short. You need to go with a 4.5" rudder minimum.
            Doug
            Doug, I see on one of your previous posts, you used a 3.5" Fuller rudder. Was that OK, or is the larger 4.5" you mention above recommended?
            • Doug Smock
              Moderator
              • 5264
              #36
              Typo flyboy, thanks for catching it.
              Here are some tips for painting styrene,
              Here are a few pics of the setup we used on the prototypes.
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • Jeff Wohlt
                • Jan 2008
                • 2716
                #37
                Great hull for wire drives. Easy to put in and I will be running a .078 in one.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • Darin Jordan
                  • 8332
                  #38
                  Jeff,
                  Just so you know (if you don't already have one in your hand), the stock motor location on these is going to necessitate a pretty steep motor angle and as a result, a fairly arched stuffing tube... I was thinking of wire also, but if I do it, I'll be mounting the motor way forward to relax the shaft... Might be more work than I want to do, so I may just build it straight up and as designed (for one... ) and just have some fun with it...
                  Darin E. Jordan - Renton, WA
                  • flyboy320
                    • Mar 2008
                    • 88
                    #39
                    What size flex cable are you thinking for this, .13 or .15?
                    • Darin Jordan
                      • 8332
                      #40
                      I don't put anything less than .150 in any boat that is going to run open 2S or higher... I'd do .150 in this boat if I were doing flex for an LSH setup or N2... I am likely going to set mine up for LSH with an SV27 motor (our club rules) and I may follow Jeff's lead and use a .078 Wire... That's what I'm using in my 1/10th scales and it seems plenty strong... If I decide to just keep it simple and build it as designed, however, I'll use .150 cable... reliable, simple to work with, and strong... K.I.S.S. basically...
                      • flyboy320
                        • Mar 2008
                        • 88
                        #41
                        Thanks Darin...
                        • Doug Smock
                          Moderator
                          • 5264
                          #42
                          Darin is right.
                          Jeff, Darin,
                          I did some checking in the shop when I saw your posts on the wire drive.
                          It looks like moving the motor forward and the cells (LiPos) back you will still be able to get the CG where you need to with some adjustment.
                          The only issue maybe if your two cell packs are wider than about 1 3/4"
                          Doug
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Diegoboy
                            • Mar 2007
                            • 7245
                            #43
                            Darin is right.
                            Jeff, Darin,
                            Doug
                            Would you be so kind as to illustrate this one?
                            • Jeff Wohlt
                              • Jan 2008
                              • 2716
                              #44
                              Maybe the way it is set up...my Classic only has about a 7" wire drive in it and a decent angle.
                              Wire drives need not be straight. They can run in cats just fine with a nice j bend. It just needs a nice bend and I keep it straight several inches from the strut nose.
                              I do not know what angle the motor mount is but I have not had any issue with a hydro yet. Dougs Classic has a pretty good angle and I relaxed it a bit but it runs out great with .062 wire running a 4T plett and 12 cells and 642.
                              I just think when looking at efficiency the smaller wire has it...granted...it has to stay together. .078 or 2mm wire will hold up to 32 cells and 140 mph...we already know that.
                              I will get one of those and see what is up. I like my motors forward on hydros....this puts the motor torque more on the front sponsons.
                              www.rcraceboat.com
                              • Doug Smock
                                Moderator
                                • 5264
                                #45
                                No,
                                Let Jeff or Darin do it. After all, they are the ones who want to re- invent the wheel.
                                JUST KIDING,
                                I'll try to post a pic tomorrow afternoon, unless Darin beats me to it.
                                Keep in mind that the hull has some extra reinforcement where the motor is
                                designed to go. This will need to be addressed if you move it forward.
                                Darin and Jeff have already come up with a plan for this I bet.
                                Doug
                                PS Just a bit of background.
                                Phil's boat varies only slightly from Garry's original design. The motor was placed where it is because that is where we could get the CG right with LSH and N-2 setups with both NiMH and LiPos.
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
