Thanks gimp!
My FighterCat Daytona 37 Build...
Even tho i have no expirience with the Daytona/Genesis hull, level with the bottom is exactly where i'd start. I do have a 32" Aeromarine Sprint Cat .21 nitro that ran really good and thats where the strut was set, pretty much a good rule of thumb with cat hulls.Comment
Yup its a good starting point. Ill have to dig up old posts to find where I finally ended up w/ mine when I had it.Comment
Mine on my genesis is level with the bottom of the hull on a table,, i tryed moving it up alittle someone had recomended it to me but then the hull started the wah wah thing so i moved it back, now thats with my setup thow!!Comment
Looks like Christmas came early for me!! Just got a bunch of stuff from OSE including the Leopard 4074 1800kv motor and the Seaking 180 ESC. I also got the programing card for the 180 as well, have to read the intructions a bit more, this ESC seems a little intimidating at first glance, but a nice looking unit! I'm actually a little supprised how big the ESC really is, takes up a bit of room, glad to have Gimps boat for a reference as to where to position it and run the wires!!
IMG_0322.jpgIMG_0323.jpgComment
Fear not Matt, i've been working on it!! I just got the rear hardware re-mounted and this time i got it right!! I was a little more carefull about drilling the first hole, then i bolted on the strut/bracket minus the rudder and drilled out the other 3 holes, much more precise now! Plus I've been doing the "body" work to the hull using some Bondo spot filler to smooth out the hull join seem, got the port side ready for primer, about half way done with the starboard side. I think i have a paint scheme thought out, just have to find the right colors to go together and figure out a lay out. Probably gonna go with a Sublime (bright Mopar) Green with some blue/purple/silver/red graphics!
IMG_0325.jpg IMG_0327.jpg IMG_0328.jpg IMG_0329.jpgComment
Good job 01, looks like you got the gear nice and even and the bondo work looks good too,, i didnt realise these hulls came with a seem around them, but good work.Comment
Thanks! Yeah there is a pretty good over hang at the seem, would stick out like a sore thumb with a nice paint job so out comes the Bondo!Comment
Playing with paints and colors, this is what i've come up with for a paint scheme for the Daytona so far! I painted this test peice for a couple reasons, one to see how well the colors go together and also becuase i'm using 3 different brands of paint to get those particular colors and i wanted to make sure all the paint's and clear were compatable! The middle purple color looks different depending on the light, goin from more blue-ish to purple, brighter darker, the pics make it look more on the blue side. What do you guy's think??
IMG_0337.jpg IMG_0335.jpg IMG_0338.jpg IMG_0340.jpg IMG_0339.jpgComment
I think it looks sweet,, im not crazzy about the red, maybe a silver or charcoal gray in its place but its your boat if you like it i say role with it..Comment
