Carbon Genesis Cat Project
  • ddayka
    • Apr 2010
    • 48
    I am fairly green to FE boats, this is #2 for me. I have a lot invested into this already, and want it to be perfect. I have a Swordfish 240 HV, Leopard 4082 1250 KV, planning to run on 8S. I will post pics as it goes along. Firstly I am having some graghics made for the boat. So I want to install my cowl locks first. My question is what is the best way to drill holes in the carbon. I am a little worried about cracking the Hull.
    Dave,
  • LarrysDrifter
    Big Booty Daddy
    • May 2010
    • 3278
    Drill bit. Hold a piece of wood on the back side and drill with light pressure.
    • ddayka
      • Apr 2010
      • 48
      Here is what I am starting withDSCF4502.jpgDSCF4503.jpgDSCF4504.jpgDSCF4505.jpg
      • Mattwarner
        • Aug 2011
        • 487
        I am just starting my build on one of these too, using a single 4082 but a 1600kv to run 6s, are you not reinforcing or sealing the hull first?
        • ddayka
          • Apr 2010
          • 48
          Sorry for the inexperienced question, but what do you mean by reinforcing & sealing?
          • Mattwarner
            • Aug 2011
            • 487
            I am a newbie too so dont worry! but having done a lot of research on here and fighter cats forum everyone seems to get some carbon fibre cloth and using resin, check out my thread here:
            • ddayka
              • Apr 2010
              • 48
              So I have first started with designing and dryfiting a stand for the boat. I will post a picture when I find out where my wife put the camera card. Stand is going to be great for working on and transporting the boat.
              Dave,
              • Alfa Spirit
                • 2131
                I used the foam from from the box to make a perfedt stand for my HOTR cat. I will do the same for my Genesis
                • jj2003
                  HIGH VOLTAGE ADDICT!
                  • May 2011
                  • 1501
                  Dave,
                  Spot on with what LarrysDrifter stated. Very light pressure and take your time. Put something underneath it for support. Dont be in a hurry, just use a sharp drill bit. Cheapy's will dull out quickly so use a good quality bit.
                  "If guns cause crime, all of mine are defective"
                  45"Speedfreek
                  , Fightercat #068 ​, MyYoutube Vids
                  • jj2003
                    • May 2011
                    • 1501
                    Follow this thread, it'll give you some guidance. These hulls are VERY strong but running at high speeds is the death of all hulls that are OEM. On 8s you'll be approaching that that QUICKLY!
                    45"Speedfreek
                    • Alfa Spirit
                      • 2131
                      Yes it' s very strong but when carbon brakes is like breaking glass. Fiberglass works more like a chock absorber
                      • ddayka
                        • Apr 2010
                        • 48
                        Ok here is photo of cat on new stand. next will be tub test & cowl locks install.
                        • ddayka
                          • Apr 2010
                          • 48
                          Ok here is photo of cat on new stand. next will be tub test & cowl locks install.stand.jpg
                          • ddayka
                            • Apr 2010
                            • 48
                            Well between working rediculas hours and family obligations it seems no time for hobbies. I am also trying to get an other mono hull set up for my son. Which I should try to finish since it is parked in the perfect work space for the cat. I did manage to get a tub test done. I weighted down the hull placing electronics in approx locations. I also applied additional pressure to the hull to overweight the hull. after approx. 30 minutes the hull was still bone dry.tub test.jpg The batteries in the photo are only for weight purposes. I am using TP 45-90C 4S 5000's I have received too many dead batteries from HK. Next I want to install hatch locks. This worries me a little since I have only one chance for this. I need to take very careful measurements, and be very careful not to crack the CF. I am thinking of drilling small hole thru both hatch and hull at the same time, and then using dremel grinder cone to ream out. I have tried this on FG with success in the past. Any better ideas?hatch locks.jpg
                            • Mattwarner
                              • Aug 2011
                              • 487
                              I agree use a tiny drill bit all the way through the hatch and hull and then use a dremmel. Checked mine this weekend and no leaks either
