Delta Force Cyber Storm Red Pics + Need Tips
  • Drax21
    • Jul 2011
    • 1021
    Originally posted by LarrysDrifter
    You have too much exposed flex shaft between the collet and stuffing tube. Id pull the tube and put in a longer one. You only need 1/4" max gap between the two.
    Hi I haven't heard of this before. What problems will a larger gap cause?
    Everything that has a beginning, has an End
    • Drax21
      • Jul 2011
      • 1021
      Battery stand now fitted made out of balsa wood. Can use the 2 plasticard pieces if need be to make a parallel set up(making it wide enough). Will run this boat on a single pack first. Picture is of a 4s 5000mah Lipo on the battery stand.
      • Drax21
        • Jul 2011
        • 1021
        Recent additions. Velcro on the balsa wood battery stand. Heat shrink on the end of the stuffing tube onto flex cable. Couldn't take a picture of the back as camera wouldn't focus but I have also put silicon all in the back between the hull and the stinger to stop water coming up the stuffing tube. Completely dry now
        • pyroM!KE
          • Jan 2011
          • 375
          Cool..So have you been running her? Where did you end up with the CG? I just bought everything for my Cyber Storm..Ill be building her up next week..Im gonna try and stuff 6s in there.. :) If you can get some pics of the back that would be awesome.
          • Drax21
            • Jul 2011
            • 1021
            [QUOTE=pyroM!KE;373150]Cool..So have you been running her? Where did you end up with the CG? I just bought everything for my Cyber Storm..Ill be building her up next week..Im gonna try and stuff 6s in there.. :) If you can get some pics of the back that would be awesome.[/QUOTE
            CG can be seen from pics. It is balanced on the front . If I tap the Hull if falls forward. Its around 9 inches from the back. Hopefully you can make out the pics of the silicon in both gaps under and over the top of the stinger.
            I haven't got it running yet....so little time and weather hasn't been great. But first opportunity and I will get a vid uploaded.
            • donthavta
              • Jul 2009
              • 176
              I have a yellow Cyber Storm that I got from Ray Fuller . What set-up are you running. Thanks Ron
              • Drax21
                • Jul 2011
                • 1021
                Castle Creations 1515 Motor 2200KV
                Seaking 180Amp Esc
                M645 Prop
                Turnigy 4s 5000mah 40c
                Will get a vid uploaded soon!
                • pyroM!KE
                  • Jan 2011
                  • 375
                  #23
                  I will be building my CS by next weekend..Everything is supposed to come in on the first..My setup is gonna be
                  SK180
                  Leo 4082 1550
                  6s2p 3000mah in parallel
                  x447/3
                  Follow my build here.. http://forums.offshoreelectrics.com/...Cyber-Storm-33
                  • Drax21
                    • Jul 2011
                    • 1021
                    #24
                    Look forward to that Top Speed Mike. I looked at a Castle 1518 1800kv before buying the 1515 2200kv. I think the max on the 2200kv is 5s. Your set-up will be great for racing!
                    • Drax21
                      • Jul 2011
                      • 1021
                      #25
                      RTR. Took out the battery pads along the sides, sanded down and coated in a permanent red ink. I have completely filled in the back of the hull where the stinger meets the hull so I do not get any capillary action( water coming up stuffing tube). You will also see the silicon tubing I have put around the stuffing tube onto the flex cable. Just acts as a small barrier in case any water does come up the tube. Also is helping to stop cable whip seeing as my stuffing tube is a bit on the short side.
                      • Drax21
                        • Jul 2011
                        • 1021
                        #26
                        • Drax21
                          • Jul 2011
                          • 1021
                          #27
                          • pyroM!KE
                            • Jan 2011
                            • 375
                            #28
                            Looking good. Looking good. When are you gonna get that in the water?
                            • Drax21
                              • Jul 2011
                              • 1021
                              #29
                              Think I'm waiting for the water to come to me Should be Saturday. I will get a vid uploaded as soon as I get back. Any problems, you should be able to help me.
                              This has got to be the best looking boat I have had.
                              • pyroM!KE
                                • Jan 2011
                                • 375
                                #30
                                Something I see is your tubing you have on your stuffing tube..I know your using that to keep water and grease out..but I would trim that back ..You only need very little touching the flex shaft..You will get drag and could rob MPH and cause your electrics to run hotter.. Look at mine..Thats all it takes..
