Fightercat Daytona
  • Rumdog
    • 6453
    Fightercat Daytona
    Finally got started on this. Single drive, Neu/CC 1515 1y Fine Design offset strudder. Should be fun. I may just build this to sell if anyone is interested. It will most likely get the CC MMM esc as well.
  • 6sHyper
    <<<Surfs up!
    • Jan 2011
    • 597
    mamb monster ESC? i dont think you'll have very good luck with that in a boat.
    • keithbradley
      • 3663
      Are you looking to go dry in this hull or do you plan on water cooling the motor and /or esc? I am doing a build right now with absolutely no water cooling...should be interesting...
      www.keithbradleyboats.com
      • Rumdog
        • 6453
        Water cooling the motor. And yes, mamba monster esc. It will work fine. I've done it before.
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3480
          Let me know if you want any vinyl for it. I'll be happy to cut some up for ya.
          • Rumdog
            • 6453
            Hmmm, vinyl huh? Maybe. Should have the parts to finish her up tomorrow hopefully. Should be a fun boat to run. Very easy hull to build and work with as well. No reinforcing needed!
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Yeah, I've got some Oracal black, white, diamond plate, carbon fiber and some funky sparkle effect. I can cut whatever artwork you want in a single color.
              I also have some 42mm motor supports that should be here in a few days. That mount is stout though, so might not even need tail support. I'm using that same mount with a 1717 and no problems.
              • CHUD
                • 497
                Hay
                Rumdog how much was that hull bud.
                • Rumdog
                  • 6453
                  Cant recall. Ask the guy who posted above you. He is the importer for these.
                  • CHUD
                    • 497
                    www.fightercatracing.com
                    Thank's bud /Good luck on the build/
                    • Jeff Wohlt
                      • Jan 2008
                      • 2716
                      I will be starting on mine soon. New 100mm stingers and FC motor mounts with Leopard 2200 twins and 2x 180 ESC with 5S each and 447 L&R cut down to 445s and tweaked...should be good for 70ish easy.
                      Oh, cermic bearings going in to the 100mm stingers.
                      www.rcraceboat.com
                      jwohlt5362@yahoo.com
                      • Rumdog
                        • 6453
                        Thats the setup I run in my Maritimo. Except the CC/Neu 1515 2200's. Expect much more than 70.
                        • keithbradley
                          • 3663
                          I wil l be starting a Daytona build very soon as well
                          Just got the hull today and I cant wait to get started. I ordered outrunners for it but I have considered running a twin setup based on the single setup that I run in my River cat (3674 Tacon 1300kv on 8s).
                          Still waiting on that Maritimo vid by the way...
                          • Rumdog
                            • 6453
                            Today's run was a joke. So windy and cold. Blowing snow. Still fun I guess. I'll get a vid for sure at some point.
                            That Daytona will FLY with a setup like that! I'm just looking to have a fun sport boat with this one. I most likely will sell it. It was a spur of the moment type build. Had the hull for a while. Was going to go twins originally. I figured, hey I've got most of this stuff laying around, and I've got a couple hours today.
                            I'm sure somone will want it. It will be a MUCH better alternative to buying the RTR Genesis.
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3480
                              There's a few 1300kv motors arriving tomorrow.
                              Wow, snow. It was 90 here last week. I really am spoiled. Explains why there are still so many Canadian plates on the road.
