32" hotr 90+mph
This topic is closed.
  • RandyatBBY
    • Sep 2007
    • 3915
    #301
    Originally posted by Fluid
    I have had great luck with the v900 props on some cats for SAW runs. But the v947/3 has a lot more blade area than the P230 and may overload your motor - or not. The only way to tell is to actually try it. The v942/3 may work fine too.
    The v900s do have a fair amount of lift although not nearly as much as the 1700, 2000 or 2100 series.
    You will have to experiment with prop depth on your cat, I had to run my strut centerline even with the sponson bottoms with a bit of down angle at the prop end of the strut with the v900s, but that will vary depending on the hull.
    Sometimes moving the CG back is needed, sometimes not.
    It will take awhile for the v900 to hook up off the beach, be patient.
    Great info Jay. It could be the reason my set up did not work on my cat. I will have to try your set up. I had the shaft center line about 3/8 above the ride pads. you ran it much deeper. We have a SAW coming up next month in L.A. the SC27 and the SC33 will be tested with this change one at a time. I was running 45,000 to 55,000 RPM's, were you running in this range?
    I have found with the V900 props that if they do not hook up right away you need more RPM. How do you feel about this Jay?
    Randy
    BBY Racing
    • yiyito
      • 5
      #302
      Originally posted by Howard Lee
      What esc do you have? I have a swordfish 240hv and run it on the middle setting. What are you look to get out of your boat? Are you happy with just cruising the lake or something faster then that?
      Hi:
      Howard my ESC Turnigy 180 and the propeller is to octura X640 and my gps is running 54mph, I run a little more mph...
      • Howard Lee
        • Nov 2010
        • 198
        #303
        Originally posted by Kyoto
        Hi:
        The 1st thing i would do is set the prop angle to 3.0 mm and then adjust your batteries to were the boat rides good. When you get the bow to have a hop then move the batteries a 1/4 forward until the hop is gone. Before going with a bigger prop you need your setup right or you will just pull more amps then you need to. You should do 60 with no problem. When i started i had that same setup and run 60 but i don't remember what prop i used, i have 15 props and many test runs. I would say try a x442 and check your speed. If you have problems with steering you might want to think about a offset rudder.
        • Howard Lee
          • Nov 2010
          • 198
          #304
          I'm thinking about building a new boat that will run 110+. Building this boat to sell but ready for saw. I will do some more testing with the boat i have now to see if i can really do it. Just look out for the Howard Lee special.
            #305
            I was running 45,000 to 55,000 RPM's, were you running in this range?....I have found with the V900 props that if they do not hook up right away you need more RPM. How do you feel about this Jay?
            I was running around 40K for the records. You may have to work at the best adjustment for the v900s, I thought I could run on the tips like we do with hydros but no. Too deep and they lift too much, but at the sweet spot they worked great.
            • Howard Lee
              • Nov 2010
              • 198
              #306
              I just finished rebuilding this ABC but its my 1st rebuild, so if the weather is good ill try for a run. I need to see if the 100 is a glitch or it is what it is. If the prop is off to much i will not run it, it will only damage the drive shaft and bushing. If this hits a 100 i will stop showing my speed test and build 1 for saw. This hull was very steady in the water at 100 thats why i think it will go 110+.
              • keithbradley
                • 3663
                #307
                I just ran mine about a week ago and was amazed how well it holds the water (not going as fast as you but still fast enough to blow it over). The only problem I have is the torque roll/torque steer. I have an inline prop and it seems to be pretty finicky.
                If the prop is out of balance, it wont turn nearly as high RPM either, the boat will be slower. You will let us know if you confirm 100, right?
                www.keithbradleyboats.com
                • Howard Lee
                  • Nov 2010
                  • 198
                  #308
                  With a single motor the left side will lift. I have my 5s on the left and 4s on the right, i like the left side to be slightly heavier. My boat has a slight pull to the right but under full throttle it go's straight. If i had torque steer in this canal at my speeds it could go bad. Also i spend a lot time checking that my steering is tight and no flexing. The offset rudder is a big help. Another thing my boat is heavy so it is very planted. If the weight your adding adds hp then do it. I got the wife up to vid but its to windy. I'll try 2morrow, i really want it on vid.
                    #309
                    Two 'secrets' to help a cat get going very fast....
                    • Howard Lee
                      • Nov 2010
                      • 198
                      #310
                      Yes your right BUT!! I was giving a hint but i will just tell you. Forget about the rudder and think just how a boat rides. If 1 side rides deeper you will get more resistance on that side, its will cause a pull. Now you are trimming your rudder to make up for the pull = lower speeds. Set the rudder straight with the hull and balance from side to side. This is for 1 motor setups. It will take all the things i have talked about to make the boat go straight on full throttle.
                        #311
                        What most do not realize is that a part the roostertail is hitting that rudder, pushing the transom to the right and helping to counteracting prop walk. I got this tip many years ago from Ed Hughey, who set many many FE records.
                        A fast boat is not just a lot of voltage, a high Kv motor and a big prop. It is a system of many interrelated parts working together. Most folks don't understand or appreciate that.
                        • Howard Lee
                          • Nov 2010
                          • 198
                          #312
                          Get mad let it all out
                            #313
                            • yiyito
                              • 5
                              #314
                              Ok my friend thanks for the tips
                              • Howard Lee
                                • Nov 2010
                                • 198
                                #315
                                Just teasing with you.
