spartan I had to do it
  • fastisgood
    • Apr 2010
    • 126
    Hay guys just some pics of small mods
  • Make-a-Wake
    FE Rules!
    • 5557
    Looks good! What motor is it...Castle?.............1520?
    • fastisgood
      • Apr 2010
      • 126
      Thanks Yes it is Im new to this I hope this works out
      • Make-a-Wake
        FE Rules!
        • 5557
        That motor is a pig........6s? If it doesnt twist the hull in half it should be the fastest Spartan ever...............
        • fastisgood
          • Apr 2010
          • 126
          twist humm cant have that I need a better hull what would you use ? Thanks
          • Make-a-Wake
            FE Rules!
            • 5557
            It shouldnt actually do that, but there will be some serious torque.............it should work ok if you dont run a huge prop.........try an x442..............
            • fastisgood
              • Apr 2010
              • 126
              ok thanks
              • CHUD
                • 497
                wellcome to ose
                NICE Pick up's bra ,I would love to see a pic of the boat's paint job ,did it come like that!!!
                • fastisgood
                  • Apr 2010
                  • 126
                  it came like that traxxas spartan
                  • JackBlack26
                    • May 2007
                    • 905
                    Nice!
                    • kjohnsiii
                      • Oct 2010
                      • 116
                      I am def staying tuned in on this one, my bro just picked one up.
                      • fastisgood
                        • Apr 2010
                        • 126
                        I Thank
                        • shctexas
                          • Jan 2011
                          • 156
                          Great job on the in-hull inlet installation. I'm considering the same. I suspected there was a double wall on the hull; I did not realize the inside tapered away from the outside. Questions, please....how did you handle the back-fill on the gap between the hulls? Did the thickness of outside hull match the offset of the inlet, in other words did it mount flush on the outside? did you use a sealant, other than what appears to be JB weld?
                          And, does it leak? I appreciate the input. Thanks.
                          • fastisgood
                            • Apr 2010
                            • 126
                            Yes the inlet are a match with the hall I use CA glue to hold in place and JB weld with no leaks
                            • shctexas
                              • Jan 2011
                              • 156
                              Thank you sir.
