Oh yeah, I saw Steven got the 1521 1,5d 8mm shaft motors in, but still no 5mm which are the ones I need. Sounds like you got some things done, I'll be looking forward to those pics. My C5000 is sitting under the tree, just waiting to be built :)
New HPR 115
Get the bats your going to run in it to find COG.other wise it will be off.ill be by to pick up those Neu's for my boat.Comment
Larry, bring some 6s packs over here so we can figure out the CG.
Dom, I got the two 1521's with the 8mm shafts. The couplers are a little big, but I think they will work fineHpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230Comment
I was originally planning on getting the 8mm shaft ones, but since I'll be running 2mm wire drive there aren't any couplers I could find. Many more options for the 5mm shaft.
Oh and that reminds me I should order my bats as well.SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
Here's some pics. The water pickups didn't turn out as well as i had wanted, but they still don't look bad. The motors are just set in place, still need to decide on there final placement.
Lookin good.You can use my 6s packs,but if you arent going to use them,I wouldnt mock up COG unless your going to use them.I dont suggest using them.I think you should get the stuffing tubes in before epoxying motor mounts in too.Just use the motors bolted to the mounts for mocking the stuffing tubes for alignment.It also makes it easier to install the tubes.Comment
I almost forgot-dont get too far on your build.Im still ahead.Not that it matters-Ill be ahead of you on the water anyway.Comment
Looks good man! And as Larry said, you should get the stuffing tubes in before mounting the motors. I see you're also using a single water intake on each side, I was just thinking over whether I should use single or double - since I bought single. But I think I'll stick with the single to keep it out of the way of the stuffing tube.
Anyway, I really like how it's coming along. Can't wait for the maiden run!SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y'sComment
I can tell you it is the revised 115.Dont know the width though.Ill guess at 12" at least.
Wheres Eric?Comment
List:
1. Stuffing tubes
2. Steering
3.Motor mounts
4. Esc, Bec, Etc...
5. Beat Larrys boat.Hpr 115, Neu 1521 1.5d x2. Delta force Pirate, Insane 45" Neu 2230Comment
