Spec Miss Vegas build
  • HYDROJERRY
    • Jan 2010
    • 2503
    #61
    Mine did the same so i put a 442 on it and it got up alot faster but mine has no leaks,,,
    • Brushlessracev
      • Oct 2010
      • 136
      #62
      What motor you running I went with the leopard 3660 2030 kv
      • Rottenbelly
        Captian Big Nerd !!
        • 89
        #63
        I ordered a 2300 and a 2600 turnigy to try out. Then I am gonna look at a better motor when I find a good kv to run. I am running a 42 x something prop but I am also gonna try a 40x57 3 blade lifter.
        My work boat has 12,000 HP!!!
        • Brushlessracev
          • Oct 2010
          • 136
          #64
          Post a update, almost done. I really want to put her in the water but its frozen. BUMMER.
          • Shooter
            Team Mojo
            • Jun 2009
            • 2558
            #65
            Nice paint! You'll have a lot of fun with it and you won't be upside down as much as the smaller boats! Very stable running boat.
            I ended up vacuum forming a hatch/cowl for mine. Flat tape all around for leakproof seal. The nose attaches like the UL-1.
            • Brushlessracev
              • Oct 2010
              • 136
              #66
              Well i think she is ready but no water to run her in. This has been a long build took a month to do but i think its ready for the water.
                • 9488
                #67
                right on man, cool job!
                • Brushlessracev
                  • Oct 2010
                  • 136
                  #68
                  finally got to run her today, have some tunning to do. timing on the motor was set at 0 deg i try my little box for my sea king but its broken only used it a few times what a POS. I tried data logging too and my eagle tree is a POS too.
                  • TheShaughnessy
                    • 1431
                    #69
                    Did you ever get your MV going?? You can still run p sport hydro with that motor just not spec. I am setting up a MV for p spec. Got it going ok the other day, I don't see why 40's would be a problem with the ul1 motor and the right prop and adjustments.
                    • Scamp73
                      • Dec 2011
                      • 95
                      #70
                      About to tackle this myself. If you guys have any pointers you have figured out along the way please let me know.
