Mine did the same so i put a 442 on it and it got up alot faster but mine has no leaks,,,
Spec Miss Vegas build
I ordered a 2300 and a 2600 turnigy to try out. Then I am gonna look at a better motor when I find a good kv to run. I am running a 42 x something prop but I am also gonna try a 40x57 3 blade lifter.My work boat has 12,000 HP!!!
Post a update, almost done. I really want to put her in the water but its frozen. BUMMER.
Nice paint! You'll have a lot of fun with it and you won't be upside down as much as the smaller boats! Very stable running boat.
I ended up vacuum forming a hatch/cowl for mine. Flat tape all around for leakproof seal. The nose attaches like the UL-1.Attached FilesComment
Well i think she is ready but no water to run her in. This has been a long build took a month to do but i think its ready for the water.Comment
right on man, cool job!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
finally got to run her today, have some tunning to do. timing on the motor was set at 0 deg i try my little box for my sea king but its broken only used it a few times what a POS. I tried data logging too and my eagle tree is a POS too.
Did you ever get your MV going?? You can still run p sport hydro with that motor just not spec. I am setting up a MV for p spec. Got it going ok the other day, I don't see why 40's would be a problem with the ul1 motor and the right prop and adjustments.Comment
