Spec Miss Vegas build
  • wparsons
    • 461
    #31
    Originally posted by Brushlessracev
    I Decided on a leopard 3660 2050 KV with a 40x57-3 blade this should work real good. i was wrong in the earlier post cats and hydros run a different class. according to the rules the leopard motor is legal for the cats but not for the spec class. your allowed a motor up to 40mm dia and 60mm long if i am reading the NAMBA rules right.
    If you actually plan to race it, check what people at local clubs have for classes. Just because it's in the NAMBA rules doesn't mean local clubs follow it exactly.
    The last thing you want to do is build it one way only to show up at a race and find out you can't race because it doesn't match their "spec" requirements.
    Light travels faster than sound, so people may appear to be bright until you hear them speak.
    • Brushlessracev
      • Oct 2010
      • 136
      #32
      Originally posted by JMSCARD
      I personally would ditch the inline rudder idea... I would go with what works.... I am sure folks have tried it, I know we don't see any and that probably for a reason... hydros work well with offset rudders... they handle like no other when set up properly with a offset rudder I don't see how they could be any better then they already are.... the only boats that i have had luck with inline rudders is a twin cat... and thats for obviouls reasons.. my inline rudder triton was twitchy... fast going strait but really unpredictable in the turns.... do yourself a favor and go offset.... don't make marks in the nicely painted hull just to go back to an offset rudder later... lol..... thats a nice looking boat all the while!! good luck....
      Cool thanks for the advice, i am going to try one way and if it does not work i can always switch it. Not like its perm. I like trying things that others have not. Strut and ruder does not cost much anyway.
      • wparsons
        • 461
        #33
        ^^ Keep in mind that the rudder is less effective and disrupts the flow of water off the prop when it's inline. It's one thing to try idea's that haven't been tried, but an inline rudder on a hydro has definitely been tried many times before.
        • Brushlessracev
          • Oct 2010
          • 136
          #34
          cool thanks off set it is, i figured out why they mount the rudder on the left of the prop on a hydro anyways makes sense why a inline rudder does not work.
          • Brushlessracev
            • Oct 2010
            • 136
            #35
            Sorry brushless55 but i am repainting the boat. i cut the nose off and attached it to the hull. I am in the process of making it water proof. i sealed all the holes in the hatch antenna hole and exhaust and so on. Removed the nitro motor mounts and gas tank mounts. its going to be three different coolers of green and silver and white. MTN DEW "DO THE DEW" will be the theme. I am having someone at a local sign shop do the graphics in vinyl. I think its going to look cool. I will Get some pics as soon as i get it done. have every thing on order motor speed control and some odds and ends. I already have rudder and strut and cable.
            • Brushlessracev
              • Oct 2010
              • 136
              #36
              Hull is in primer had a local shop gel coat it after stripping, BY THE WAY DO NOT STRIP UNLESS YOU USE STRIPPER FOR FIBERGLASS. Found out the hard way. Sealed the hatch openings with carbon fiber. latches on rear of hatch where filled.
                • 9488
                #37
                Get after it bro!
                looking forward to the new DEW!
                • Brushlessracev
                  • Oct 2010
                  • 136
                  #38
                  Get after it bro!
                  LOL
                  • Brushlessracev
                    • Oct 2010
                    • 136
                    #39
                    Got all my hardware in, strut, rudder, cable, motor mount. Waiting for servo motor and speed control. and few odds and ends.
                    Added some pics of rudder and strut, motor mount.
                    • Brushlessracev
                      • Oct 2010
                      • 136
                      #40
                      New dew
                      Got some of the painting done, still have some too do be for clear coat goes on.
                      • Make-a-Wake
                        FE Rules!
                        • 5557
                        #41
                        Lookin' good!
                        • teach
                          • Jun 2008
                          • 509
                          #42
                          Looks great!
                          Have you given up on the idea of a spec system? Would be great to have another show up for a little racing.
                          • Brushlessracev
                            • Oct 2010
                            • 136
                            #43
                            Originally posted by teach
                            Looks great!
                            Yep went with a leopard motor and 180amp sea king.
                            • teach
                              • Jun 2008
                              • 509
                              #44
                              Oh well, maybe next time.
                              • Brushlessracev
                                • Oct 2010
                                • 136
                                #45
                                Still run it with the specs not going to be any faster then a stock UL-1
