yeah that looks like a cool hull, where did you get it?? I have a new 1520 that would probably work pretty good in one, and i'm looking to build something similar...................
40 inch offshore
how much amp draw can a t600 1400kv pull? I think a 1717 would be the good ticket in this ultra light hull.I may end all the speculation and put a 5692 in there and turn a 457 like I really want to.I tell you one thing this t600 is a smooth feeling motor and it has the pole "bump" I like to feel in a motor. Its built well it appears.
I would be a fan of the 5692 in that boat, but the 1717 would work well if you are looking to run a lower cell count. There is a guy on OSE that just built a 40" mono with a 1717 and got 59mph out of it. Pretty respectable if you ask me!
I have a build going on right now with a 5692 but its a little bit larger and probably much heavier mono.Comment
...I tell you one thing this t600 is a smooth feeling motor and it has the pole "bump" I like to feel in a motor....
If you like the feel that's great, but don't use that to define motor quality.
BL motor cogging has nothing to do with quality or performance, it is a reflection of motor design. The fastest FE boat in the world ran a motor with no apparent cogging at all. Some Neu motors cog, some do not depending on their specific design. A cheap outrunner a club member had cogged like no body's business- but it threw a magnet and burned up it's first run.
.Last edited by TotalPackage; 02-26-2011, 05:22 PM.Comment
They're rated at 110A max.
x642
x645
k51
x457
k57
Crab got some good runs on his cat with a H5017 so an x1750 octura?It seems monos like 4 series better though so Im leaning toward th k51.Comment
I have gotten 140amps on 6s out of the t600 1400kv but make sure you cool it very well and don't go that hight for too long. And it can take 120 amps all day!Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover bargeComment
Ran it today with the k51 ran kinda wet but is was pretty quick. The motor was room temperature and the esc was cold the water flowed through the system nicely. you could see a nice small continuous stream,BUT one of my packs swelled? Only got one run so next time ill get a chance to adjust the strut and possibly prop up. The t600 turned the k51 with ease on 6 s. I may need to calculate some proper batteries for this system and install a cap bank.Attached FilesComment
Props under 50mm are too small to be very efficient on that large hull. Your swollen pack could be from:
- too high an amp draw for the pack C rating
- over-discharged the pack due to not fully charged, different capacity, etc.
- shi**y quality pack
Reporting "temperatures" is meaningless without including the run time. Reporting "room temperature" (calibrated thumb?) after running one minute is not too impressive. After ten minutes, it means a lot.
Total, I'm thinking you need 2p and an x452...................NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
When I had the 750 kv kb with the x457 on there it ran really stong but that was really a low rpm. I was kinda scared with this t 600 1400kv to just start with the 457. The k51 is all I had between the x457 and the X645. I also have a k57.Its loose in the photo Ryan,the struts just hangin there, but when I ran it had maybe a 1/8th inch gap. You think it need be more?New charger just arrived todayHow do you calculate the amp burst capability of the lipos,and others; anyone?
ps even though the kb's max amp draw aprox(95amps) is less than the t-600's (110amps) it didnt seem az big az the kv difference which was almost double so I thought the kb probably had a little more torque. Whats the physics behind it Jay?Last edited by TotalPackage; 02-28-2011, 11:43 PM.Comment
some progress! Got a new charger the other day tooAttached FilesComment
