Delta Force Sniper 45 on 12S
  • Punisher 67
    Ignore list member #67
    • May 2008
    • 1481
    #76
    I use the V3 150amp unit
    • RaceMechaniX
      • Sep 2007
      • 2824
      #77
      Originally posted by Anbjorn
      I will give mine a try again in a few minutes.
      New firmware? For the 40.300?
      Interesting picture of your 40.303.
      Do you have a higher resolution picture of it?
      Does it have the new pp60-300 connectors on the motor side?
      I got mine back from Schulze with wires soldered directly to the female outputs.
      Here are pictures before and after the uprade at Schulze.
      Anbjørn
      Yes I do have a higher res image, shoot me a PM with your email.
      Yeah they did upgrade the motor connector to the big 300A units. That is kind of a bummer that they soldered wires in place of the connectors. It may be worth sending back when you have some downtime to have them upgrade it with connectors.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • RaceMechaniX
        • Sep 2007
        • 2824
        #78
        Originally posted by gerardobrandao
        LOLOLLOLO
        Only you Tyler..only you....
        That´s pure mechanical engineering talking.....
        When you have a chance too look at the data, give me an input.....
        That way i could compare your data to mine......
        Very Best Regards
        Yeah will do. I downloaded the data to my desktop at home instead of my usual laptop so I need to transfer it over when I get home.
        TG
        Tyler Garrard
        • Anbjorn
          • Apr 2009
          • 248
          #79
          Well, tried to connect to the 40.300 again.
          No luck.
          Anbjørn
          • RaceMechaniX
            • Sep 2007
            • 2824
            #80
            Did you notice anything in the hyperterminal (the text column on the right hand side of the screen in future-soft)?
            Did you try changing the connection port in the software? The auto port does not work well unless you by accident get the correct port the first time. Look under the "connection" then "properties" tab and change the "connect using" drop down menu to another option.
            Tyler
            Tyler Garrard
            • Jacked1
              • Jun 2010
              • 772
              #81
              Originally posted by RaceMechaniX
              You guys make me want to build something outrageous now.
              outrageous=40.303wk+3080/5+10S 10k mAh 45C hyperion batteries
              Put two in a HOTR cat on 12s! 27Kw!
              Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
              • RaceMechaniX
                • Sep 2007
                • 2824
                #82
                Anbjorn, Gerardo
                I found the problem for connecting to a computer with 40.300 or 40.303. I will write up a little how to.
                Tyler
                Tyler Garrard
                • RaceMechaniX
                  • Sep 2007
                  • 2824
                  #83
                  OK guys, see the attached PDF for connecting a Schulze 40.300wk or 40.303wk controller to a PC. I checked that it works on both XP and Windows 7 (even 64bit is OK)
                  Let me know if the steps work for you.
                  Tyler
                  Tyler Garrard
                  • Anbjorn
                    • Apr 2009
                    • 248
                    #84
                    Tyler, that worked
                    I managed to connect to the esc with the future-soft and download a pack of files (.lad file)
                    I then opened the pack in akkusoft and got alot of graphs.
                    However I have no idea what I am actually reading or if it is correct or not.
                    Tyler, maybe I can send the lad file for you for "translation"?
                    Anbjørn
                    • RaceMechaniX
                      • Sep 2007
                      • 2824
                      #85
                      SUPER!
                      Yeah sure, do you know how to read the Schulze data? See the attached PDF I did for Gerardo. I would like to see your data regardless though to get an idea for my next project.
                      Send the .lad file in a compressed zip file please so it will go through gmail with being flagged as malicious.
                      Tyler
                      Tyler Garrard
                      • Anbjorn
                        • Apr 2009
                        • 248
                        #86
                        Email sent as zip file.
                        I think I did download it correctly as it did look the same as in your document.
                        Anbjørn
                        • RaceMechaniX
                          • Sep 2007
                          • 2824
                          #87
                          Got it. Your data looked very good. Temperature was only 54C max and RPM was pretty good. Current measurement still does not work, but that was the change between the 300 and the 303. I sent you a screen shot of the full data set.
                          Tyler
                          Tyler Garrard
                          • Anbjorn
                            • Apr 2009
                            • 248
                            #88
                            When moving the cursor over the graphs I can't see the data at that point.
                            What rpm values did you see?
                            Anbjørn
                            • video200
                              • 837
                              #89
                              that looks great anbjørn.
                              now i only need to get NC in bergen next year to have a closer look on the boat hehe :D
                              • RaceMechaniX
                                • Sep 2007
                                • 2824
                                #90
                                Anbjorn,
                                I see about 30060 as the max RPM on the last run you did. To view the cursor info select the "info" pull down menu and select "cursor info".
                                Now you should be able to see the cursor data.
                                TG
                                Tyler Garrard
