FC I built one like this and it works. I would stay away from the ski type bend in the front. I found out that it will make it ride up on top of the boat your trying to push. Also make sure its plenty wide in between the pontoons...(300' across the lake its like trying to thread a needle) hope this helps
PVSea Monster!
I'm considering some music wires through the tubing to help "hook" the distressed boat if partially submerged or if the PVC just want's to go over the top of it. I think it should be able to overcome the drag from a few wires hanging down.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I think I may have found an EDF fan mount solution though. 74mm fan inside a 3" PVC.
I could use a 3" to 2" PVC reducer as a cone...
We'll see. Going to the hardware store soon to find out.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I've found that 3" PVC will work for mounting the EDF jets, so have two of them setup for this PVC Monster. Two full Kilograms of thrust!
The plan is to use a V-Tail for steering.
I'll save the propeller setups for the boogie board as there is a transom to work with and more room for tupperware. =) Heh, time for a twin motor boogie board! (twin 380)
More to follow next week.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I'm not sure how fast it will be, but it should giddy up for sure!
I'm thinking if I use a 3" reducer and a stretch of PVC that I'll be able to direct the thrust up or down by positioning the stretch of PVC towards the tail. I'm not really sure of the angle of thrust needed at this point, so leaving room for adjustment.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Just a quick update. The Fans are in, the tubes are cut, the v-mixer is ready... All I need now is a good day of creative energy to come along!
=)FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
http://forums.offshoreelectrics.com/...ht=contraption
theres one already built if you need some inspiration. I am building one with danny that has twin props and breaks down for easy transport. we are building ours to go after our small stuff and the 1/8 scale hydros we are working on.Comment
If it works well, I may retrofit mine with EDFs instead of the steerable outdrive that I currently have. I like the idea of not having anything below the rescue boat that could snag on something in the water.
Here is a pic of my PVC rescue boat with my custom boat lift.Attached FilesSoCal Fast Electrics|H&M Drifter S-CC1512/4S/T180A|Aeromarine Scorpion 32"- UL-1/4S/HM200A|Insane 34- CC1515 1Y/4S2P/T180A|BK Bandit S-CC1515 1Y/4S2P/T180A|Insane FE30 UL-1/4S/ETTI 150Comment
Well... Lookey heeeer what I finded. Turns out my old computer case had induction fans... same size as my EDF's. How cool is that?FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
It's moving right along!
OK, took me a bit to program the ESC's and get the V-Tail mixer setup for turning. There's a delay in signal response, typical of cheap air ESC's. Makes the steering a bit delayed.
The V tail steers by increasing one side and decreasing the opposing side's fan velocity.
Headed for the pool test today. He he.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
