Another Catamaran Build!
...I think the turnigy 120 would be more than adequate for your motor/battery combo...
Got mine to 51mph with an X440/3 blade on the 8Xlmotor.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Interesting build!
I don't understand the dual water pickups, but they look cool. I run everything off of the rudder pickup and into a Y connector and have been pleased with the results. There is a good amount of water pressure to tap in to. Careful of the drag created by the transom pick ups. I know some were having problems with symmetry and handling due to placement and depth of the pickups.
I've been running an x440 (2.19") on 3s2p in a CC/Neu 2650 Kv powered Apparition (same hull bottom- same RPM as your setup) in the 43-45mph range. Headed to an x442 (2.31") next. The 642 (2.64") might be too much as I have amp draw issues with the x445 (2.47"), although you might get away with it running lower KV and higher V.
Hope that made sense and hope that helps.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Interesting build!
Hope that made sense and hope that helps.Comment
You'd be surprised how many amps you can draw with that motor. It can give spikes well over what the 120 model is rated to take. While the x642 is probably safe, you know how it goes - the owner has to keep going up in prop size to get that extra speed and pretty soon he's running an x560 and pulling 140 amps. I'm always a proponent of using a bit more ESC than you think you'll need, that helps to reduce the chance of burn downs.
.Comment
The Turnigy 180a is a tight fit, but can be done. It has a large footprint. The hull you have has a little more room between the motor and the hatch nose. The wires do hit the hatch though. That's with the ESC flat on the hull, using a thin layer of silicone to hold it in place.Attached FilesFighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
The Turnigy 180a is a tight fit, but can be done. It has a large footprint. The hull you have has a little more room between the motor and the hatch nose. The wires do hit the hatch though. That's with the ESC flat on the hull, using a thin layer of silicone to hold it in place.Comment
Hey, I just have a quick question. Seeing that I put a 3/16" shim on my 4mm prop shaft to fit a bigger prop, Should I get a 3/16" Drive dog as well and use a shim, or should I keep the one I have?Comment
AFAIK- keep the same size dog as the shaft.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
As Fightercat says,you need to keep the same 1/8 drive dog so it fit tight on the shaft.If you put a shim below a 3/16 drivedog to make it fit on a 1/8th shaft,it won`t tight fit on it,its gonna spin around.............also make sure you flat spot at the motor and prop shaft in order for everything to get a tight fit!!!!.............AlComment
