Another Catamaran Build!
  • mbartley27
    • Jun 2010
    • 39
    So here I have my 1st Catamaran boat build ever.. Yep, so that makes me a Newbie. I got the Hull 32" from Ebay, it`s one of the Chinese hulls. The brushless motor is also from Ebay.. It`s a 2075Kv 8Turn. I'm gonna get a Turnigy 180A ESC to control this bad boy. For power, I'll be using two 4s Lipos ran in parallel. It has a 4mm prop shaft, but I put a 3/16 brass shim on it to run a slightly bigger prop. Now, I have no idea as to what size, pitch, diameter prop to run... Any info will be helpful... Thanks.
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    A safe starting point would be a good ole trusty Octura x642 IMHO.
    FE BOATING: Less like a hobby and more like an addiction!
    • mbartley27
      • Jun 2010
      • 39
      Thanks for the advice.. I'll order a couple when it`s finished..
      • blackcat26
        High Speed Junkie
        • Sep 2009
        • 1598
        Anytime bro. You will probably need to go bigger after testing the temps. This is just a good "all round" prop for many different boats.
        • mbartley27
          • Jun 2010
          • 39
          Nicee.. I think the prop is the single most confusing thing for me.. Size, Pitch...but I'm sure I will be educated by many of you expert boat builders here....... Do you think my setup so far is good?
          • blackcat26
            High Speed Junkie
            • Sep 2009
            • 1598
            You are off to a good start. One thing I noticed was the water line on the portside and the battery pack on the starboard might get in the way of the "main batteries" Before you nail anything down semi-permanent check out your COG with all components in the boat. Ideally your COG or balance point will be somewhere around 28-33% from the back of the transom. On a 32" boat that translates into roughly 9"-10.5"
            • Jeff Wohlt
              • Jan 2008
              • 2716
              Mine runs upper 40s with a 442
              www.rcraceboat.com
              jwohlt5362@yahoo.com
              • mbartley27
                • Jun 2010
                • 39
                Absolutely.. I was looking at that as well... Everything can still be moved if need be.... But thanks again for the input.
                • mbartley27
                  • Jun 2010
                  • 39
                  Here are a few more pics of my setup.
                  • Karfrik
                    • Jun 2009
                    • 1177
                    do those water pickups come like that from the seller?....there must be a better way for making them aesthetically more pleasant.I don`t like how those hoses come arched all the way from the transom,sorry,but thats me.
                    Browse/search around here so you find a better looking alternative,same at OSE store.I`m also looking at buying me one of those cats soon,but just with hardware.How do you rate their fiberglass quality built?....Albert
                    • HYDROJERRY
                      • Jan 2010
                      • 2503
                      Why do the motor wire connectors look backwards,,,shouldnt they have been solderd the other way arround??
                      • blackcat26
                        High Speed Junkie
                        • Sep 2009
                        • 1598
                        I think that the "female bullets" are connected to the male's. Most of my motors were shipped this way, makes them harder to lose I guess.
                        • mbartley27
                          • Jun 2010
                          • 39
                          I understand your question, but the wires are soldered the correct way... It looks backwards because I pushed the female connectors onto the wires so I don`t loose them.
                          • mbartley27
                            • Jun 2010
                            • 39
                            I ordered the water pickups from another seller... When I did I sure thought they were gonna be smaller than that, but that`s the look I wanted... I may change it a bit so the arch isn't that big, but otherwise I think I'm gonna leave it like that. The hull build quality is very good to me. I think it could be a bit thicker for the bottom, but everything else looks squared away. Thanks for commenting.
                            • blackcat26
                              High Speed Junkie
                              • Sep 2009
                              • 1598
                              Keep the pickups they will work just fine. Just make sure they are in the water flow so they function. I could not tell from the pics but they look a little shallow.
