..and you bent the mounts also. i was debating doing that or just using a wood wedge. KISS, I guess. Less parts is a better way to go.
Das Boot - Generic 32" Twin Cat
FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
The cable exit points are very close to the EKOS and allows the wire to be almost straight. Unless I have any problems, I'll keep them here. With the stingers being so far behind the hull, I don't anticipate any issues.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
She's ready to get wet!
I found a pair of 70 amp ESC's that should work perfectly for this boat. They are air cooled, so mounted them next to the outrunners fans. On the dry dock test, I couldn't get them to produce any heat at all. For starters, will be running 3s, 3000mah 20c packs. They are nice and light, the whole boat weighs in at just over 5lbs. 2515 grams.
Starting props are the 36mm 3 blade counter rotating Venom props. I also have a set of 447's ready to test.
Overall I'm really happy with how it turned out. It's not perfect, it's not show quality, it's not bling... it's Das Boot. My first DIY FE boat.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
I think the total build cost came in under $300. I'll get an exact number once I'm happy with the performance and final configuration.FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
Looking good! Well I hope your maiden run is successful.
Lately, everytime I go to the lake I have nothing but grief. Honestly, sometimes this hobby can be so discouraging. Damn tunnels! lol."IT IS BETTER TO REMAIN SILENT AND THOUGHT A FOOL THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT"Comment
I would make a suggestion to maybe tape up the motor connectors to avoid any possible arcs or short circuits.
NIce work, i hope it runs as good as it looks! No bling my eye, thats a sharp cat man!
I have the same mounts as you, just slow as heck. I'm building a larger cat right now with 7S & a single Turnigy t600 outrunner, monster 4030 motor.
Careful with 47mm props and 70 amp esc's... you might cook something there....Nortavlag Bulc
Thanks for the tip on the connectors. I really didn't notice how much gold is showing!FighterCatRacing Team CHING BLING - Ching Bling. Brilliant, Advanced Sparkle for your hull.Comment
