Darin's Top Speed 2 FE Conversion...
  • ice329
    • 792
    #76
    I am waiting on a prop, will start with the X642. Motor angle isnt set yet but I will start out even. The balance point is very close to the 9 1/2" mark prob more like 9 3/4. Gonna use two 7.4V 5350 MaH Lipos. Gonna start with this. I dont race I just like to have something that I could if I felt like it. Well see what happens... Almost tested it today with just a CF42, its all I have that fits right now.
    • Darin Jordan
      • 8335
      #77
      Sounds like a good place to start... Let me know how that 642 works out...
      What brand of batteries do you have that are 5350mah???
      Darin E. Jordan - Renton, WA
      • ice329
        • 792
        #78
        Did you guys GPS these boats with the SV power plant.
        • Darin Jordan
          • 8335
          #79
          We did initially.... Best I got was 38mph... but that was on a setup that would go for 10-laps (just barely... batteries were VERY close to the danger point... )...
          We've since upped the prop size, and started refining things a bit... I'm betting we'll be into the 40s with this setup this season...
          Then we'll see what a Modified setup will do ... 4S in a Tommy Lee/Rod Geraghty hull with a Neu 1515 and Hydra 240... Might be SCAREY!!
          • ice329
            • 792
            #80
            I may have condemed the SV radio syatem a bit early. I was concerned firstly because of the glitch, that is serious. I was thinking because of how I had to run the antenna and motor power wires etc, that the AM radio was picking up motor current or the higher Volts of the Lipo's etc were causeing the glitch and it may have been. I swaped the radio to a PM3 and moved the reciever back to my original thought out spot, it just eliminates having to run things all together. I place the batterys in the PM3 and they were practically dead, so this may have also caused the glitch in the SV radio syatem. At any rate the TS2 should be good to go again. It real cold out but I may still run her today.
            Something else I reolized while reading the manual. My fitting I used for strearing are actually the fitting they sent for the the throtal linkage if you used a gas motor. Not sure if they will hold up but I like how they fit and they are strong so we will see, it sure make it look clean. I am a big fan of clean and open, I hate clutter.
            • ice329
              • 792
              #81
              Slight bobble number 2. I went with the Dubro mount. If I did it again I would have went with the other one the guys are using. I ran the boat yesterday with a CF42, I wasnt getting enough lift on the nose so I went positive as far as the mount would allow. Still not enough. I turned the mount upside down and get more adjustment but now the motor just looks a tad high. I have no adjustment down if I need it. Ya I can remount it. Just sayine if you do one of these conversions go with the other mount or keep this in mind when mounting the dubro. I got a X642 yesterday, so even though its 34 deg here I will still be making at least one run.
              PS This thing turns on a dime and is incradably stable. Freakin thing is awsom.
              • ice329
                • 792
                #82
                I know you guys already did all this... but... I ran mine today, new Bal/shapened X642 and the reversed mount. I bet I picked up 10 MPH but the motor is no doubt to high. I cant hold the boat in the corners, I can but not like I should. I will reset the mount and give her another try. Got a 2" chop on the pond today, the stability is unreal. The stock SV servo works fine, I have to tone it down because it seems to responsive.
                • ice329
                  • 792
                  #83
                  I lowered the motor. seemed better but as I am running I am saying something isnt right.. I must have said 5 times during the run. After the run I open the hatches and check, everything is bone dry. I wipe the boat down, nice and dry. I see water? I open the black drain plug. The boat is full of water..... At least 7 or 8 ounces .... hummm I did not cut the deck to mount for the boxes. I did not screw anything into the deck or hull. What the H_LL??? I tore the boat down. I filled the bath tub up. Dunked the entire boat. Bubbles from the motor mount holes. Taped them up. Dunked the boat, check up and down. No bubbles. Must have been the motor mounts, has to be even though there above the waterline. So I will remedy the bobble and retry.
                  Before I tore the boat down I make a call to Hobbico, there customer service is definatly good. They were gonna honor the hull possable problem even past the 3 months and were gonna let me keep the cowl with Mickey on it.
                  • crazzy maxx
                    • Dec 2007
                    • 498
                    #84
                    check the water cooling...
                    snort pixi sticks=symptoms-:
                    • MOTOboat
                      • Nov 2007
                      • 6
                      #85
                      WoodStuff
                      Darin,
                      What length of hull is your woodstuff?
                      I have a 32" Woodstuff I was thinking of using instead of the TS2.. Initially I thought the WS would be too heavy but it is an awsome handling hull with a 3.5 KB SS. Just a little underpowered as my motor is stock.
                      I acutally find the Supreme FE more fun to drive (Sport only) as you never quite know if it is going to flip.
                      I look forward to your results.
                      MOTOboat
                      • Darin Jordan
                        • 8335
                        #86
                        Originally posted by MOTOboat
                        Darin,
                        Mine is 28"... It's kind of a tight squeeze to get everything inside it, but I managed... Haven't tested it yet... but I anticipate it going fine with the SV27 setup on there...
                        32" might be a tad big for the SV27 setup...
                        • MOTOboat
                          • Nov 2007
                          • 6
                          #87
                          WoodStuff
                          I have a 1515 1.5 & 1Y I had for building a TS2 FE... but have been looking at the Woodstuff thinking of converting it to a FE.
                          This is just for fun running. I enjoy the building... I just hate to disassemble the Nitro setup...
                          But the truth is I seldom use it and it is kindof under powered.
                          MOTOboat
                          • Darin Jordan
                            • 8335
                            #88
                            I think the 1515 1Y has a lot of potential on that 32" tunnel with 4S1P power... or 4S2P if you can fit it... Might not be necessary to go 2P... if you get the new Elite 4500 30C cells, they should be able to handle 1P fine if you don't overprop it...
                            That'd be a fast combo...
                            • MOTOboat
                              • Nov 2007
                              • 6
                              #89
                              WS or TS2 FE
                              Probally a lot better choice than trying to keep the TS2 on the water?
                              • Darin Jordan
                                • 8335
                                #90
                                In my opinion, YES... We've tried the TS-2 with the AMMO 2300KV motor and it was FAST... but the handling wasn't great... not great at all...
