Darin's Top Speed 2 FE Conversion...
Set up correctly, the VS-1 totally rocks !2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
Peter, The VS1 comes with the stumble blocks already factory mounted. When you get my hull and get the motor and electrics dropped in, you will see what this boat can do! It turns on a dime! MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
no one have an opinion on no cav. plate?..........is that a no no.......really
could use some feedback on this k&b modded outboard
you can hurt my feelings i can take itSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
I've never used one so cant be sure but I would have thought that if you have it mounted up high so it operates in surface drive mode I cant see how a cavitation plate would be of any use.Paul Upton-Taylor, Greased Weasel Racing.Comment
I seem to remember a discussion of this on the IW outboard forum, but I can't locate it. If you post the question there I'm sure you'll get some answers. What I do know is that quite a few REK users have trimmed it off to run larger diameter props with good success, apparently.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
