Avery, I am sure another member here that has the knowledge needed will chime in and help. Just be patient. I sure would like to see a pic of those ESC's and motors though. Also, You might want to reconsider using those props. They look like they have some serious pitch and end up destroying your electronics.
hpr ct04 67 inch cat build
yeah i plan to use the cheap one from ose and start with 40 mm and work up to what will work i just need to get rid if bec on the esc acording to xfactor and i should wind up after testing and going up on props eventualy wind up between 40 to 50 mph with motor and esc he suggested so hope someone will chime in. just copy this and put in search on ebay and that is the esc i have ( 200A EP RC Car Plane Brushed Motor Speed Controller ESC ) and this is the motors ( High Torque Panasonic 12V 14.4V 18V DC Motor Hobby)Comment
pictures now on a heli esc to disable the bec you just take the red wire out as i have done in picture and that disable it but i tried on this one and it still get power from motor battery so not sure i mean it will operate motor with red wire off but see there is a switch wired in to this esc also that the red and black lead small wires so any input would be apreciated also xfactor if you read this please email me at [email protected] and let me know how to disable bec so i can move forward with build not sure what happened but i didnt do nothing and though you were ok you spoke you mind that what make world go round thanks if this gets going one day i will be happy with 40 to 50 mph for now till i get straighten out with incomeComment
6S , what are the max Volts and amps these motors may/can handle ?
How many rpm per Volt ?
6s on such a large hull : that means : low rpm motors and huge props ????
I don't wanna be rude, but I don't think your setup will work............Comment
not sure but was planning on running a aluminum tube through the heatsink for a way to water cool the esc motor didnt seam to get hot and will have ventilation in hull when moving so if i can keep from pulling more than 200 amps maybe it will work guess order some props and give it a try huhComment
i ran the motor with esc on bench for while just testing alittle no equipment to monitor punching it and reversing it stoping and punching it for about 3 minutes and the heat sink got real hot on 6s so i am concerned about it if water cooling will do the trickComment
Avery those motors will work no proble but get some esc that will handle it . They were worth a try but when you look at the little wire that says it all no way can the handle that much you need some nice high voltage esc from astroflight or maybe member andy kunz can help youLast edited by TotalPackage; 07-26-2010, 01:25 PM.Comment
