test to see if i can post pictures not to savy ont this stuff well here it goes of works i will post all pictures to date well any who check this could you tell me how to get my pictures from pictures folder to this forum pretend like you talking to dummy in fact dont pretend lol
hpr ct04 67 inch cat build
Hay Avery, the way i do mine is i load them into My Documents under my pictures, on the site you do like your going to post something but do the go advanced thin then near the bottom of the page you will see manage attachments hit it then you click browse and a window comes up and you go to my documents and my pictures then double click the pic and it will show an address in it then hit the close window and scrolle back up and post it... -
i can pull up attachments and pull up picture file but caint figure out how to get it to the post that the problem i alrdy did other stuff just caint get it to post when i hit close window it closes but nothing goes to post caint find out how to get it to post hit post picture and dont know if that will work trying it nowAttached FilesComment
some five blade props im currently cutting down and shaping they r stainless i made themComment
my servo mounted for rudder and some cardboard templates i made for motor mount and esc mount and battery mount and some carbon fiber blue setting up so i can cut out motor mount and battery tray ectComment
hull hanging in camper and outside overall pictureComment
I am sure the servo is just a place holder for the brushless, digital, aluminum-bodied, titanium-geared, 300oz monster that will take its place when he finishes.Comment
forst off thanks guys for comments ill try and answer if i seam a little here and there it the meds im on see when i started this i was ok but since begginning i have come down and fighting cancer of the salava gland in upper palatte mouth sugery s were rough but any. i plan to use the little screamers for motors as caint afford the 2230 neus any more and the hife swordfish cheaper than the shultz 40/160 batts will be 12s2p each motor and for servo well have to admit first time this big a boat so the traxas no good well dam can yall recomend a cheap one that will get job done as no income right now and none for at least a year have plenty of time though lol oh the first batch of carbon fibe is done and started another one more and the motor mounts batt ,and esc mount will be rdy to cut out of pieces i made had cloth about two years now new it would come in handy i mad parts for my dirtbike wich i caint ride for while but it look good anyway plan to order motors next week but ose say two week till they get them so i made dummy motor so i could setup shaft and motor mout and such so will be rdy funds slowing me down but ill get there evetualy thanks again all
ps they came with hull from hanspeter the snorkels that isComment
very nice boat and your build will be great, the setup should be fine. I wish you all the best and quick recoveryTwin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
thanks i did some balancing with lead weights i got the weight of everything and build little lead weights and placed in hull and got boat to balance at cg point hanspeter recomended so i can mount everthing ie motormount esc and battery mounts then when i get the actual items just bolt in or strap in and rdy to go
still trying to decied what props to start with probably 60mm low pitch and go up from there then try out my custom made 5 blades and see how they do and adjustComment
