shooter yours is plexyglass wich is a type of plastic wright maybe you can heat yours alittle and get it to bubble out alittle for the extra clearence but if it where me i have a factory place that sells plexyglass nearby i would take it to them and see if they could do it,,or they could give you some ideas...cuz they would no..Just had a thought if you put a seal under the PG and use a bolt in the middle to hold it down, getting rid of the tapeing idea the seal may keep the PG up just a hair high enough for it to clear the motor...
Miss Vegas brushless conversion
I'll try heating a practice piece and see what happens. Maybe if I heat the top and use a pc of wood from underneath to form the shape I want??? I'm just worried it will warp the outside edges. Right now it fits like a glove.
The seal idea sounds good in theory, however, everytime I've tried a seal like that (without tape) it leaks. My #1 priority is keeping her dry. Taping on a flat surface very rarely lets me down. Tried and true.
I just performed my "bathtub leak test" yesterday. I do it on all my boats before the maiden voyage. It involves holding the entire boat underwater (completely submerged) for 1 minute. She passed with flying colors....not a drop of water.Comment
Jerry, you are a gentleman and a scholar! Great advice on heating the plexi. I was able to make a real nice hump above the motor!I used a wooden handle from a file and pressed it into the plexiglass after heating. It's still crystal clear. Thanks! The cover is actually on in the second picture. Tough to tell since it's clear.
Aww, sweet you cant even see it, man i wish mine would have been like that,,How did you cut it, i now last time i played with PG when i tryed to cut it it would crack...Comment
