4 Prop Conquest build
  • rearwheelin
    • 1941
    #226
    Did some gel coat work tonight.........Hope it turns out, was mt first time geling !
    --Albert Einstein
      • 9488
      #227
      looks clean!
      • riptide1
        • Feb 2011
        • 241
        #228
        looks good white on white I like the touches around the brass
        • rearwheelin
          • 1941
          #229
          Allmost ready to ship !
          L 48'' h 11'' w 21'' wieght 44 lbs.... Just need to make sure i didn't forget anything before i screwed the top down.....
          --Albert Einstein
          • crrcboatz
            • Jan 2009
            • 914
            #230
            Wonderful build. I am doing a 36" team believer with twin 1520s and was wondering whether to put them in the sponsons or as you mounted the 1717s here. Which ocation do you recommend? 5 or 6 s 1p for each motor.
              • 9488
              #231
              No way!
              I was just looking at that hull two nights ago to possibly put two of my CC1520 motors in
              • Boaterguy
                • 1760
                #232
                who's the lucky guy getting this boat?
                • rearwheelin
                  • 1941
                  #233
                  HaHaHa , I just ordered one today !.......I am going to run 1515 1Y's in the sponsons. There are trade off 's running them in the middle and running in the sponsons. From my expieriances running in the middle gives better turning and more voltage spikes due to the greater surface imperfections of the water. Runing in the sponsons gives the boat a more stable feel and draws less amps and voltage spikes but less high speed turning abilities , also less bend on the stuffing tubes....I am not 100% sure wich way i am going with mine yet. More than likely in the sponsons....Let me know if you would like me to make you a cf motor plate for a sponson mount.. It wouldn't much extra work for me when I get around to making mine. What kv are the 1520's....My speed goal is to go around 60+ mph, so 4s for me .
                  --Albert Einstein
                  • rearwheelin
                    • 1941
                    #234
                    Shipping tomarro !
                    I am going to miss my baby !! Ships tomarro , PP recieved, ......R.I.P. my quad.
                    lol....Thanks Brian , was a pleasure
                    --Albert Einstein
                    • crrcboatz
                      • Jan 2009
                      • 914
                      #235
                      1518 = 1800kv
                      1520 = 1600kv
                      • rearwheelin
                        • 1941
                        #236
                        1518 = 1800kv
                        1520 = 1600kv
                        5s will probably put you in the high 50's depending on your prop, 447x 2 blade. In the high 60's on 6s. T180's probably won't even sweat.
                        --Albert Einstein
                        • rawsonreyes
                          • Aug 2007
                          • 102
                          #237
                          all i can do is dream
                          hi guys those are some great builds but cant afford such right now so all i can do is look and dream on.great work guys.
