Yes, you should have it in a day or two. Not sure how long it takes but figured about 7-10 business days...so they told me.
M12 maritimo
Update water cooling
I have finished the water cooling in the Cat.
In the first 2 pictures you can see the water enters the motor at the bottom and exits at the top.
Then it travels back down the aluminum tube and exits at the transom (pic 3).
I've put all the servos and the receiver , gyro in to the back of the hull to figure out how I'm going to fix everything .
She's starting to fill up!!!
The Cat is almost at the perfect balance point now, without the lipos.
So it should make it real easy to fine tune the cog later.
Next update Paint
Bonewar
SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
Update strut
Got my strut in the mail today.
Thanks Jeff.
So i got busy!! And sorted out the mount for the strut .
As you can see, i have put the strut in the back of the hull to
get the prop close to the end of the transom.
I will make a small access hatch on top of the transom so that i can adjust the strut later if need be.
The rudder and strut are held in place with a aluminum angle 40mm , 25mm
then bolted throw the transom for a very strong and clean looking back end.
Still have to drill the hole for the strut adjustments.
Now to paint her!!!
Bonewar
Thanks mate.
I bought the carbon fiber kuhlers from AndrewG . http://www.fastelectrics.com/blmotors1.asp scroll down the page and you will see there are lots of choices.
They are very nice looking motor coolers , shinny.
Bonewar
J.M.
Have to agree.
She's pretty ugly on the outside.
FOR NOW!!!!!
THATS THE BEST COMMENT YOU COULD COME UP WITH.
WHAT I DON'T POST ENOUGH PICS FOR COMMENT.
COME ON MATE YOU CAN BE MORE CREATIVE.
Bonewar
Update strut
I've finished mounting the strut , all holes drilled and bolted.
Made a water prof area at the back of the transom so if water leaks in past the strut bracket it will be confined in that small place.
Also going to water prof the top and side of the strut bracket with carbon fiber plate and some silicone to stop the water entering the hull.
The strut and rudder set up is solid and is adjusted with 1 bolt, Access will be throw a small hatch on top of the cat.
DONE!!!!
Bonewar
When are you going to come up w/ some original ideas?I've finished mounting the strut , all holes drilled and bolted.
DONE!!!!
Bonewar
Your pretty sick... Rick.
Thanks Scotty.
MASTER PIECE IS THE CALL!!!!!
FINAL MARITIMO.
O'yer 1 more to build yet HPR ???TWIN.
2011 project.
More on that at a later date.
Couple of pics access hatch.
Bonewar
Mine will probably only compare in that its a HPR.......
Attached FilesComment
Now come on Scott,
That HOTR TWIN you just built is a very nice boat.
Built well and finished well.
And very clean.
Just the way i like my boats!!!
You got skills brother.
Bonewar
