After a reasonably successful scratch build of a Hydromite I've been bitten by the bug and want to turn my hand to something a little bigger. Unfortunately the Hydromite never quite made it to the water. Not long after it was completed we moved house and it kind of got crushed by the movers. My wife told me it was my own fault for leaving it lying around!
Anyway after searching around at all the options I decided on a scaled down Wild Thing. After getting my hands on a copy of the 48" plans I scaled them down to 32" and spaced the stringers a little further apart at 4" to make a little more room in there. After sorting out the drawings I decided to make a mock up in card just to check that everything would go together ok, and before sending them out to get a quote on laser cutting the parts.
Lots of card and PVA glue later this is where I'm at...
Now, as the title suggests I'm looking to do this on a budget an as such am not looking for an out and out speed demon. As far as power is concerned I was thinking of a Graupner Speed 700 BB (6316) running on ten NiMH cells. As a relative, ok total newbie, I have no idea if this will work. Is this a viable option/combination for this size of hull and what sort of performance is it likely to achieve, and what current can I expect this set up to pull? What sort of prop size should I be looking at? Will it even get on the plane?
There are so many questions.....
I had a load of fun building the Hydromite and received a lot of help and advice from this forum...... thanks guys.
I'm hoping the Wild Thing will be even more fun.
Thanks,
Gary
Thanks,
Gary
