Newbie new build delta force 26"
This topic is closed.
  • Brushlessracev
    • Oct 2010
    • 136
    Well i did my research before build a boat. Been doing 1/8th scale and 10th scale racing for many years. I am starting with a delta force 26" hull. 540 11L 2,326 RPM / Volt 5mm Shaft Motor. twin rudders. i purchased a Hobby wing 120 Pro speed control i do not know how good they are but the castle creations was out of my price range. i am going to run 2 x2s in series so 4s. going with a 40mm x 2.5 pitch prop by proboat. I put up some pics of my build when i get started.
  • Make-a-Wake
    FE Rules!
    • 5557
    I would think a 13L or maybe a 12L would work a bit better.............just my opinion.
    • driftah
      • 760
      ummm twin rudders?
      • JMSCARD
        • Mar 2010
        • 3444
        Single rudder for sure... everyone on here runs single rudder df's for a reason.... and also I agree with the 12l or 13l.... on a 120 amp speedy you are gonna be pushing that 120amp speedo hard... the 12l and 13l would be less heartache......the 13l would give you more room for prop selection and ride attitude error....
        • rearwheelin
          • 1941
          I would have gone with a 10xl and 440x 3 blade on 4s. . Go with a single rudder too.
          --Albert Einstein
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7116
            I ran a Proboat motor (1500KV) and got her into the 50s. single rudder fan here too. I was using an x640-642. that low of KV even on 6S didn't even make the hydra 120 sweat.
            "Look good doin' it"
            See the fleet
            • Brushlessracev
              • Oct 2010
              • 136
              Wouldn't a duel rudder give you more cooling and more control. i know its more drag in the water though. 25" mono is going to be very light 11l i think is going to be plenty i could always go down a prop size to lower the amp draw. 12l and 13l draw more current anyway.
              • Jesse J
                scale FE racer
                • Aug 2008
                • 7116
                The point we are trying to make is that you don't NEED more control. You said it yourself, its light and small, and will turn so fast your head will fall off - with just one rudder and good turn fins.
                Well, we all have that "lets make it go faster" urge and the lower the KV you have the lower the amp draw, period. Where did you get the information about the 12/13l drawing more current? are you talking about the amp rating for the motor? If so see this chart.
                See the fleet
                • Brushlessracev
                  • Oct 2010
                  • 136
                  I was wrong in the last post the lower the turn motor the higher current draw. LOL the duel rudder setup i think was a good idea. run twice the cooling and have better control(turn better in either direction) some jet skies do this. my boat is not being built for racing but just fun. should turn on a dime.
                  • Jesse J
                    scale FE racer
                    • Aug 2008
                    • 7116
                    If you want more cooling, you can also do this. I like these a lot. I know it may seem counterintuitive that one offset rudder will only turn good in one direction... but I can say, as many on here, that this boat is probably the best handling 26" beast out there and it WILL turn great on one rudder. Now, if you like the looks of two rudders, then that is a totally different issue and if so, then go with it!
                    See the fleet
                    • wparsons
                      • 461
                      Dual rudders won't give you more control, it will just add drag and slow you down.
                      Light travels faster than sound, so people may appear to be bright until you hear them speak.
                      • Brushlessracev
                        • Oct 2010
                        • 136
                        i know it will slow you down that not why im going with 2 rudders i just like the looks of it and give me another place to pic water up from for cooling. was thinking about 2 screws too.
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          Quote Brushlessracev - "my boat is not being built for racing but just fun. should turn on a dime."
                          If its not built for racing then why wind it up and draw big amps and higher heat with the 11L?
                          You will limit your propping choices..............plus with the added drag of twin rudders, you will really be straining your motor with large amp draw...............and again, more heat.
                          • Brushlessracev
                            • Oct 2010
                            • 136
                            everyone has a opinion! it is my boat i will build it the way i want it. thank for the info i will take it for consideration.
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7116
                              If you are going twins, you may want to think of ordering up a special two motor mount and throwing in some rails spaced at 4". It will be tight, but no reason not to try it! I am working on a twin Triton and drew up a motor mount for Peter Zicha. He took the drawing and coded up his CNC lathe and spit me out a killer mount and for not too much.... it should be here any day.
                              See the fleet
