Newbie new build delta force 26"
This topic is closed.
  • Brushlessracev
    • Oct 2010
    • 136
    #46
    anyone know what the wiring is on the Feigao 11L motor A,B,C red,green,yellow
    • Rumdog
      • 6453
      #47
      What do you mean? Polarity? It doesn't matter. If you hook it up, and the rotation is reversed, simply swap a pair of wires.
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        #48
        Twins in a mono is a waste. When the boat leans over in the turns one prop is usually out of the water causing weird handling problems. This boat is also way to small for twins. Keep it simple and you will have more fun and less headache.
        Mark
        • Brushlessracev
          • Oct 2010
          • 136
          #49
          I did not say anything about polarity. just wanted to know how every one is wiring there motors for example yellw=A and so on.
          • Brushlessracev
            • Oct 2010
            • 136
            #50
            Mark
            I am not going twins,
            • Jesse J
              scale FE racer
              • Aug 2008
              • 7116
              #51
              Mark
              half agree, boat too small yes. Twins a waste? don't agree. Beautiful sound, motors run cooler, you have a back up if one dies, no torque roll, I could go on. But yes for this hull the weight would be an issue if you did actually get all to fit in there. It sounds like you have abandoned the twins idea - maybe another hull? twins rock!
              How's progress?
              "Look good doin' it"
              See the fleet
              • Rumdog
                • 6453
                #52
                Im confused. Why are you affiliating motor wire colors with letters. Just solder in mating connectors, and hook em up.
                • wparsons
                  • 461
                  #53
                  ^^ Agreed. Just plug them in. If it spins the wrong direction swap any two wires on the motor.
                  Light travels faster than sound, so people may appear to be bright until you hear them speak.
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 979
                    #54
                    Jeese, In my 15 + years of boating I have only heard of 2 or 3 monos being converted to twins. In most of those instances they thought the boat would handle better than it did. Having the right mono and the props in the right place are very key to the success.
                    By the way I'm well aware of the benifits of twins but your comment, you have a spare motor if one dies. Really?
                    Mark
                    • Brushlessracev
                      • Oct 2010
                      • 136
                      #55
                      speed control is marked for a reason, A,B,C terminals,
                      • Basstronics
                        • Jun 2008
                        • 2345
                        #56
                        Its AC. Hook it up if it runs wrong direction flip two wires and bam... right direction!
                        • Make-a-Wake
                          FE Rules!
                          • 5557
                          #57
                          Ignore A,B,C etc..............just solder connectors and hook em up............swap any two wires to reverse if wrong.
                          • Brushlessracev
                            • Oct 2010
                            • 136
                            #58
                            cool thanks
                            • Rumdog
                              • 6453
                              #59
                              It only took four different guys telling you before you believed it.
                              • Chuck E Cheese
                                • May 2008
                                • 1684
                                #60
                                just go with it brushlessv
                                ignore all negitive comments, just a waste of time. all questions are welcome here. when i started on OSE i am sure i asked a few (understatement) of nonsence questions. all answered. as your post says "newbie" that qualifies you to ask anything you want.... if people respond with such things as "It only took four different guys telling you before you believed it" just ignore it.. i am sure he asked some stupid questions when he was new also... keep us posted on teh build and if you have any questions ask them. i have owned 4-5 DF 26" so if you want PM me...
                                see my fleet : http://forums.offshoreelectrics.com/...hp?albumid=294
