Newbie new build delta force 26"
This topic is closed.
If your leaning towards twin rudders for extra cooling the extra water isn't going to make much differance. I run a rudder with a dual pick up and it supplies 4 motors and 4 esc's and at high speed the water pressure is more than enouph, I had to fill my brass water spigits with solder then drill them out smaller to cut back the flow so I didnt blow out the water line. Question is how fast are you planing to go ? At slower speeds a second pick up is good. Speeds over 40 and a single pick up is enouph to supply a twin prop set-up. Also a second rudder will give your boat added lift at the back wich isnt good for handling and more lean from torque effect from the motor, a single rudder will cancle most of the torque effect out and your boat will ride with less lean. Just a thought. Good luck hope it works out for you.Oh....and it will turn on a dime with a single rudder !
--Albert EinsteinComment
The last twin prop mono I personally had expierance with was a Traxxis Villian. It rocked side to side, but that was my first boat . I cant speek for anyone else who has built a real FE in this setup. Probably should know what you are doing before attempting that kind of a build and check out some video's on youtube to see if it will handle the way you want. I would stick with a single prop for a boat that size, usually see twin mono's in larger size like 40'' and up."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I have the copy...
I cant imagine twins in it- to small.
Plus one 380 XL is enough to make this hull scoot good. 540L even better. Im curious to see what the 4074 2000KV will yield- insanity is my guess.
These boats handle like you wouldnt believe. Dual rudder is useless on these. If you got any more rudder it would probably flip over or something. I can WOT turns- even sharp ones- without an issue.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
If you really like the dual rudder look, I would make them shorter - like less than 2" wet maybe closer to 1.5". Twins would be a squeeze and I would probably step back to 380L cans. I can redraft the motor mount for Peter if you decide to go this route. Ya weight will be an issue, just make sure all available space is filled with flotation."Look good doin' it"
See the fleetComment
My boat almost looks like a sub that surfaced when standing still... lol42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
If you really like the dual rudder look, I would make them shorter - like less than 2" wet maybe closer to 1.5". Twins would be a squeeze and I would probably step back to 380L cans. I can redraft the motor mount for Peter if you decide to go this route. Ya weight will be an issue, just make sure all available space is filled with flotation.Comment
Heres a copy. Single rudder, look at the turns. Normally ran on 4s but heres a little extra.........
If all of your wishes are granted, many of your dreams will be destroyed!Comment
Here is my 25" Knock-Off.
Thats a 380 XL- 2868 with 2898Kv. 120 ESC and two 3S in parallel. Run times around 2-3 minutes I think been awhile since I could get a "full" run.
Hopefully I will have video & eagle tree data tomorrow.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
This one is runnig a Feigao 9L (2731 kV) on 4s Same boat and same setup i am going to do except with a 11L be a little slower..Comment
