1/6 scale Jetsprint boats and 30mm Jet drives
  • Fella1340
    • May 2013
    • 1035
    #91
    I only learned it through this thread and comparing options. I didn't think it was important option to have and I think it would require another channel on the radio anyways.
    • TheShaughnessy
      • 1431
      #92
      Because electric motors are able to change rotational direction without a transmission I bet if you spun the impeller in reverse you would be able to go backwards a bit. But who is using reverse on an rc boat?
      • mickieb49
        • May 2010
        • 237
        #93
        From all the times I wired up the motor in reverse, I do not recall that the boat ever reversed. I am sorry to say that if you wanted a boat to go in reverse then this jet unit is not for you. Please I say that in utmost respect because I would hate you getting anything that doesn't fit your requirements. This unit requires 3 channel radio, so you can trim the boat as you go, also mix the trim function in with your steering, so when you do a steering input, the nozzel points down by a few degrees , pushing the nose back in the water so it turns better.
        Remember , No power, No steering!
        Regards mick
        • monojeff
          Moderator
          • Nov 2010
          • 2562
          #94
          Regards mick
          Great info as said most R/C boats would not require reverse it was more of a I wonder type of question.
          Keep up the great work Mick!
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • monojeff
            Moderator
            • Nov 2010
            • 2562
            #95
            what type of servos are currently using?
            OSE GIFTING ELF
            HAPPY HOLIDAYS!!
            • mickieb49
              • May 2010
              • 237
              #96
              Hi I am using hitec STD servos, even micro servos would have enough grunt to be used.
              I just moved the c of g backwards, helped a heap, one of my mates was filming, he will post the video later on.
              Cheers mick
              • mickieb49
                • May 2010
                • 237
                #97
                here you go guys, was a bit rough yesterday , but bringing the c of g aft helped heaps.
                • Darin Jordan
                  • 8335
                  #98
                  OK, too cool... where do I get one! :)
                  Darin E. Jordan - Renton, WA
                  • Mike Caruso
                    • May 2012
                    • 940
                    #99
                    It does run cool
                    Do It Like You Mean It .....or Don't Bother
                    • mickieb49
                      • May 2010
                      • 237
                      #100
                      Hi Darin, just pm me with your postcode, state, town/suburb. And I can get a quote for shipping.
                      Just got a quote the other day to send a hull/jet unit combo over to the states and it was $85 AUD, I will add though if the actual cost comes back cheaper then I will refund the difference in full.
                      Still finishing off the cowl mold, so it may be a few days before I can get a hull completed.
                      Regards mick
                      • mickieb49
                        • May 2010
                        • 237
                        #101
                        psy.jpgpsyc.jpgpsych.jpgpsychot.jpgH Guy's, Just a little update, just got some paint on the hull, and the first 2 production hulls will be ready to ship out to some lucky customer in the next few days, by t he way these will be up for grabs.
                        Got the skipping sorted, changed the C of G and removed the lower lifting strakes, will get some video soon
                        Cheers Mick
                        • Mike Caruso
                          • May 2012
                          • 940
                          #102
                          Did you paint the Kat? If you did very cool I really like that one let me know if it comes up for sale. Still waiting for my pump shipping is very slow I guess because of Holidays.
                          • mickieb49
                            • May 2010
                            • 237
                            #103
                            HI Mike,
                            Yes I did paint this myself, may not be a true professional job but I am slowly getting better.
                            If you want I can do you another hull and do the same paint job, probably add $100 for the painting ?
                            I am surprised the unit has not gotten to you yet, as I posted it about a week and a half ago, shouldn't be too long then....
                            Take care
                            Regards Mick
                            • mickieb49
                              • May 2010
                              • 237
                              #104
                              Here is the finished product. The first hulls are now finished being layed up, I will be now bending up the roll cages then putting 3 kits together.
                              These first kits are up for grabs, PM me if your interested, For an introductory time I will put these up for $250 USD ea plus postage.
                              • flraptor07
                                • Aug 2013
                                • 2451
                                #105
                                Mick, they look great but may I make a suggestion? IMO The cages are too tall, if you shorten the front legs and put the rear legs on more of a angle I think it would look much nicer. Other than that these are AWSOME!!
