Hobbyking Hydropro Inception (Joysway Alpha 1000)
  • wade1992
    • Jan 2017
    • 2
    Hi
    I recently bought a joysway alpha boat and have removed the flex shaft to clean and some bearings came out. Wondering if i could get some help reassembling the rear shaft/prop support. Any ideas how it goes back together? Cant find anything on the internet.
    • martin
      • 2869
      Were all six of those bearings fitted on the shaft or were some spare ones.
      • wade1992
        • Jan 2017
        • 2
        I assume they were all in the shaft, as I only had 4 (1 flanged, 3 normal) when I took it apart and ordered a new set which came with 6 (4 normal, 2 flanged), so I lost 2 in the process. I have put it back together the only way I could but had to leave one of the flanged bearings off so the gold prop coupler could be secured in the right place on the flex shaft.
        • martin
          • 2869
          I think you will find it uses 4 bearings ie 2 plain bearings back to back at the front then the black plastic spacer then a plain bearing back to back with the flanged bearing at the rear. I think they include 2 spare bearings 1 plain + 1 flanged, as the rear 2 bearings wear faster than the front 2 bearings due to the side load put on the rear 2 bearings.
          • steve p
            • Sep 2015
            • 4
            that is good that the boat has all that how much do you want for it: send quote to :sboatman 429 @gmail.com
            thanks,Steve
            • fweasel
              master of some
              • Jul 2016
              • 4311
              thanks,Steve
              I don't believe anyone is selling anything in this thread.
              Vac-U-Tug Jr (13mph)
