Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 New HK Mono - Offshore Electrics Forums
New HK Mono
  • Tunda
    Eh no steal my slipa
    • 754
    #91
    Sounds good Paul let us know how it works Aloha.....Tunda
    Hawaiian Tunda
    • Graeme
      • Jun 2010
      • 90
      #92
      Just un boxing mine and to me the rudder seems to be on the small side for a boat this big.
      This could be why they are so unstable in turns..
      Doe's any one else think it's small ?
      • martin
        • 2887
        #93
        They turn in the typical way of stepped hulls, if you look at the Smash Shark that also comes from TFL hobby whick HK sell as well. They use the same rudder but the Smash Shark turns much better & smoother, the Smash Shark is a v hull with no steps across the hull.
        • Graeme
          • Jun 2010
          • 90
          #94
          It's still seems small to me I will try a larger one and report back.
          • IRON-PAWW
            • Oct 2011
            • 314
            #95
            The rudder does definitely seem small for the size of the hull and I too wonder whether a larger rudder could help this boat. Not a lot of experince with stepped hulls myself though. Do stepped hulls have issues with turning cleanly then?? I also found it a bit odd there were no trim tabs with the boat? Is that another stepped hull thing?
            PERTH AUSTRALIA
            • iop65
              • Mar 2013
              • 367
              #96
              never seen a stepped mono1/2 with trimtabs
              when you got everything right you don't need those "brakes"
              • Graeme
                • Jun 2010
                • 90
                #97
                Tried mine out today. Totally sucks in turns but is really stable in a straight line.
                A fun boat though
                • IRON-PAWW
                  • Oct 2011
                  • 314
                  #98
                  Any thoughts as to what replacement rudder could be a good fit? Been holding off doing anything with mine until the
                  HK warranty dept make a decision. If I rebuild I might look at a larger rudder too.
                  Too true with the trim tabs iop65, but I like em for a bit of tweaking all the same. :)
                  PERTH AUSTRALIA
                  • ray schrauwen
                    • 9475
                    #99
                    Here's a worked over mono 1 or 2?? Not sure but, this guy seems to have done a lot of tinkering on his stepped mono.
                    Notice the Carbon prop? I'd like a class with carbon props only.
                    Nortavlag Bulc
                    • Tunda
                      • 754
                      #100
                      would like to see it run.........
                      Hawaiian Tunda
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        #101
                        The turn fins on the front step looks like an interesting idea. Also, it seems that the rear turn fin is a barge board style as it seems to run forward of the transom.
                        • martin
                          • 2887
                          #102
                          Most mono 1 & 2 stepped hulls here in Europe dont use the foward fins as in the pic. One of the most common used & very succesfull stepped boats is the Etti monos. They use a single large barge board fin & turn quite well but still have a tendancy if turning to fast or to sharp to exhibit the problems that the outer limits has but not any where that extreeme. These are top class racing boats that are much smaller & lower with a very low centre of gravity which helps with turning, the outer Limits is a much larger boat that is quite tall with a higher cg which will compound the turning problems more.
                          • 785boats
                            Wet Track Racing
                            • Nov 2008
                            • 3169
                            #103
                            Some interesting stuff here.
                            ANGKA JEBRET adalah sebuah blog prediksi, data pengeluaran dan juga live draw togel online yang terkenal seperti pasaran SGP, HK, sydney, shanghai, paris loteries, london pools dan pasaran terkenal lainnya.
                            • Southwest
                              • Sep 2012
                              • 274
                              #104
                              Paul785, the site you typed is from Belgium. I sent him plans for a rigger many years ago and I think it was Walter Geens who modded it.
                              • May Liu
                                • May 2013
                                • 11
                                #105
                                Originally posted by martin
                                This boat is made by TFL Hobby, same maker of the Genesis cat. They have this boat on their website with same paint job except the name on the side is Lucky Oct, it is listed at 870mm or 34.25".
                                I happen to have the website of TFL Hobby.
