Twissted being a Lehner owner of 3 X 3080'S and 3 X 2280's I am going to clue you in a bit here - as always you always get what you pay for and the Lehners are no exception . There is no motor out there that is built like the Lehner line they have a very unique rotor design and are just packed full of wire making them easily one of the most efficient designs out there . Neu 's are also well designed but as of late I see some quality control issues hopefully that will be nipped in the butt . But needless to say a very large and extremely powerful line of motors .
So the big question why was the speed so close - Maybe cause the KV was also close between the two design's and with the same cell count the speed would have been close also . Now lets start adding power well past the manufactures rated limit similar on both motors and see if the high precision Chinese motor can handle the heat - I 'll bet you it grenades well before the Lehner even see's any stress . I noticed on your pictures of the 5850 that it was Herve from the uniques section logo next to the motors so can you explain why you are using someone else's product to make your point . I do not know you and I do not want to insult you either but you certainly have made a few ignorant assumptions .
i cannot put this any nicer but there is no F**KING way a Hor SSS5294 will push 12KV on a continual output and anyone thinking it will is an absolute retard . There is just not enough motor or mass to support those kind of numbers unless it is just for a few seconds on a saws run . I have seen the inside of a 11KV Lehner 3080 and also the pinner interior of a 4 & 6 pole 5692 the Hor's equivalent - It is like comparing a garden hose to a sewer pipe in fact a 56110 would be severely taxed trying to even come close and its a 25% larger motor . I just cannot see any magical magnetic and wiring combination that makes that motor so special and above all others .
Quit using everyone else's examples and maybe post some of your own real world experiances .
