56-102 Monster coming down the pipeline
This topic is closed.
I bought the equipment to do the same. And also to balance the motors. I'm looking possibly running 10s as the way to go. A pair of A-spec with the TP5850 motors should be just the ticket to get this build there. I think I will try the SSS5694 800kv motors first. As they will keep me in the fast and cheap mode for this build. that will keep the rpms low 3.7vx800kvx10s= 29600rpm or run it at 12sx800x3.7v=35520 this is the same as the 1200kv motor running on 8s. Which brings up the money part. I could run on 8s and not buy batteries at all, because I have 8 of the 4s batteris that I run in my buggy in series. With the SSS5694 motor in it. I did add a mesh cove to the back of the motor so that dirt would'nt harm the motor. The power is amazing!twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
Where did you buy it?
My friends tease me because instead of running my boat, I like testing and having hard Data to back me up.
This way I know what works and what does not....BUT if it works out the other way around I have to find out why?
MikeDo It Like You Mean It .....or Don't BotherComment
Sorry but I had no choice but to clean this up. Time to get it back on topic. Twisted I suggest you post pictures of your big cat builds before giving advise to other members.Steven Vaccaro
Where Racing on a Budget is a Reality!Comment
Last edited by twissted; 12-07-2012, 09:24 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
I would like to point out that this started when I was telling everyone that the sss5694 is a great motor.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
This is true. I was pointing out that the motors are rated at this rpm. I run this motor on 8s. I don't have a clue as to why people think I'm doing other wise. If I was to run 12s It would be with the 800kv motor. I would end up with the same rpm. I do think that the TP Power motors will out perform the Neu.And if money wasn't really a concern and quality was I know I would be talking to s neu. Have one custom built. I have already thought about it but the $600, I would rather burn up less expensive ones. Even the very high dollars motors will melt, split, demagnetize, seize, arc, spin bearings, short, burn, just as easily as a less expensive motor- its all in the combinations of inputs, volts, amps, watts, load, heat, ect,,,, and well post the video of you running them and your setup.
Sent from my iPad using Tapatalk HDtwissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
tp-power-5850-6y-600kv.jpgtp-power-5850-6y-600kv-1264.jpgtp-power-5850-6y-600kv-1265.jpg TP Power 5850 motors look a lot a like other than the ribs in the can. This is one of the reasons I think that tp makes the SSS line for Hor Racing.
oper;470862]I know what these motors look like, if you want I can take the can apart. And I do not believe these motors will last any time spinning any prop at 50000 rpms.
Sent from my iPad using Tapatalk HD[/QUOTE]twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
I have none at the moment. I traded it off for a LRP motor.
I take that back I have 2 Kyohso mini infernos that use the esc's and one the runs the Neu motor as well.Last edited by twissted; 12-10-2012, 03:30 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
They might look at the build that runs a pair of 5850 motors in a 94" MHZ boat. He was running Lehner motors. read the hole thing. Get back with me. It orange in color and is fast.
http://forums.offshoreelectrics.com/...(94-)-electricLast edited by twissted; 12-07-2012, 09:59 PM.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
Yes the boat ran faster with the Lehner motors (Not by much). But the big question is why. I seems that he is very happy with the TP5850 motors and it is very impressive! I think in my 60" build, that is in the near future will do well with these motors.twissted from speed. Lead, fallow or get out of the way. Copy cats in back of the buss!!!Comment
