Ok this is a real dumb question, But how many people are running 1/4" flex with these 63mm motors. Or 3/16"?
Littlescreamers 63mmwater jacketed Motor
the prop shaft is a choice between 3/16 (more prop choices) or 1/4 if you
know what you are doing with big props.:::::::::::::::. It's NEVER fast enough! .:::::::::::::::Comment
Cables
Can anyone tell me the shaft length when running these big set ups? I will be making the 1/4" cables with a step down 3/16" stub end and std 1/4" shaft soon. I guess I should know the length as well for most set ups.
These will be silver brazed.Comment
Jeff,
I think it will depend on the strut one uses... I use the standard, 1/4 cable w/step down to 3/16
that I got a long time ago, if it still the same it is 4" long (just stub):::::::::::::::. It's NEVER fast enough! .:::::::::::::::Comment
info
Scott is the motor mount braket proboat or did you make it and will it fit in a magnum 57 warehouse hobbies v hull,if so what it the proboat stock numbers for the mounting braket hardware.NiceOk
I have a little more info on the motor.
This Large Water Jacketed Outrunner was designed for big boats 40-90". It will perform well as a drop in HP replacement for the Weed Eater type gas boats. Designed as a racing motor to run against the gas and will be competing in the racing scene beginning 2010. Testing so far in a 40+ Race hydro we are running 65-68 MPH and completing 7+ laps on 10s. This is very exciting for a low cost alternative motor to be running with the $600 Modified gas motors and the Large Neu inrunners. Testing continues and I will update soon!
These pictures are from the 55" Deep Vee I am doing a conversion on. I started with a new hull (Snagged from the LHS for $50 new in the box) and then bought all new Proboat hardware, I am waiting on an ESC and then I will finish this project. I am very excited to see this thing scream across the lake with the new power system.
Order one from Littlescreamers.com Today
KV650
Shaft 8mm
Watts?? 8,000
ScottComment
Let me just say this, lol. I just got my Little Screamers motor in the mail today, haha, and there is not a damn thing "Little" about this motor! Its going to push around my 1/8th scale hydroplane project like its a joke! It has 8 gauge wires coming out of it! MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
Would this be a good choice for a 10th scale hydro? Or is this waaaay too much motor?FE BOATING: Less like a hobby and more like an addiction!Comment
Holy crap, no way to much! This motor is as big as a Coke can!Laser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
I am wanting to do a test and see if it can be run on a 3/16 shaft. 3/16 flex are pretty stout might make it. I am going to run one on 8S and see what is will do in a 45 inch cat.Comment
Thanks guys I figured it would not. Guess I was just hoping, since they are a cheaply priced power source.FE BOATING: Less like a hobby and more like an addiction!Comment
LoL...Yeah. That's what I meant. This motor makes me want to build a gianourmous boat around it!FE BOATING: Less like a hobby and more like an addiction!Comment
