JetChopper30 mono deep v hull FRP GLOW OR ELECTRIC
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
So can I get one of these ASAP or when could I get one Thanksmy youtube videos http://www.youtube.com/user/chris81983?feature=mheeComment
Hello Herve, Howzit ?
The beauty of this boat at 30" is that it can be rigged for several race classes : P-Ltd Mono & P-Ltd Offshore heat races, or P-Ltd Mono/Offshore, or even full P SAW running. I have mine rigged to run P-Ltd Mono at the NAMBA Nationals this summer. AQ 2030 KV UL-1 motor on 4S makes a nice combo and will make a really nice sport runner rigged like that. It should be a real rocket with a 4S motor of 4074 2200 KV size on 4S with an appropriate speed control. I'll be trying that after the Nat's.
DSC03072.JPG DSC03073.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Herve,
Sounds like a good combo. I'd start with a conservative prop ; no bigger than an X442 & check temps & amp draw. The Hydra 120 may be maxed out with the 3674 so be carefull. Should get you close to 50mph.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Hi Tony.
Leo has been kind enough to send me a pretty, shiny, red hull for set up & testing in our Aussie waters.
Thanks again Leo. Nice piece of work.
I'm also going to make sure the setup can be changed around easily for a few different classes that we run at our club.
Restricted Mono ... Aquacraft or Proboat 1500kv motor with the original 45A ESC. on 4s.
Club Spec... 3674 Xl 2 pole motor (any kv you like) any ESC on 4s.
EA Mono... Any motor, any ESC, on 4s.
Certainly looks promising in the rough water.
I might need your opinion on a couple of things once I get into it but it will be a nice addition to the 'Wet Track Racing' fleet
All the best.
Paul.Attached FilesSee the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Paul, I sent you a p.m.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
