Leopard 2200kv Motor
  • Steven Vaccaro
    • 8721
    #31
    They are on order, along with the diff kv rating 4074 motors.
    • sailr
      • Nov 2007
      • 6927
      #32
      Will you have the water jackets for the Big boys? I know you can get jackets from Leopard for the 40's, but not the big ones.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • RCKong
        • Sep 2009
        • 1545
        #33
        I like my new 4074 2200kv leopard motor, it pushes my DF 33 well into the 50's on 4s. It runs nice and cool. Looking forward to getting the larger motor also.
        • ED66677
          • 1300
          #34
          RCKong, what is your amd draw and what prop do you spin? sounds incredible such a high KV on a 33" hull!
          Emmanuel
          • ray schrauwen
            • 9471
            #35
            When are the BIG BOYS coming? 5692 that is...
            Nortavlag Bulc
            • RCKong
              • Sep 2009
              • 1545
              #36
              I don't have a logger, but I'm running a turnigy 180A marine and it was right around 115* after 3 min hard running, spinning a modded 642. Motor was at 110* and the batteries were a little bit hot at 121* I live in SWFLA and the water temps right now are around 90* so not to much thermal cooling available
                • 8012
                #37
                Battery temps of 120F are not at all too hot. The hotter the cells the more power they deliver, most folks recognize this. I only get worried when my cell temps are exceeding 140F. I try to start my cells at near 100F, safer on the cells and more power as well.
                • ED66677
                  • 1300
                  #38
                  that's really nice! you could probably prop up a bit! impressive!
                  Emmanuel
                  • Steven Vaccaro
                    • 8721
                    #39
                    56mm motors should be in August. Jackets wont be in for them for about 8-12 weeks after we get them
                    • Rich
                      • Jan 2008
                      • 551
                      #40
                      Sweet! I run the 4074 in my mm with x640 4s2p, 44mph temps on the caps 120f and the motor shaft 112F love this motor going to try to use 5s2p that should push me over 50!
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        #41
                        Might try the 4074 in my MM with a 545 today and see how she does...if I can get caught up!
                        www.rcraceboat.com
                        [email protected]
                        • MarkF
                          dinogylipos.com
                          • Mar 2008
                          • 979
                          #42
                          The first videos of my Insane hydro had this motor running on 4s and an H6 prop modded with 3.7" of pitch at the cups trailing edge. This got me over 60 mph. Dont be afraid to put a prop on this motor.
                          Mark
                          • Alfa Spirit
                            • 2131
                            #43
                            Those motors are midrange quality and this is a good idea.
                            We could choose cheap FSD, Feigao, KEDA motors or high-end NEU, Tenshock and Lehner motors.
                            Now we can buy good 4 pol motors for a good price
                            • keithbradley
                              • 3663
                              #44
                              Ran my Leopard 4074 today in my SV27 with swordfish 120, Oct 445 prop, and 4-2s 3600mah (4s2p) NeuEnergy Lipos. Temps were surprisingly low and this motor ran pretty well even when I ran it on 2-3s lipos (3s2p). ESC temped at 129 after running it hard for 4-5 min and motor temped at 98 (using OSE's water jacket for this motor). Temps seemed lower than when I ran a Neu 1515-1y and hydra 120 in the same boat with the same prop. Im not saying this motor is better than the Neu, but so far it seems to be a valid option and a worthy competetor to the others.
                              www.keithbradleyboats.com
                              • vasy
                                • Dec 2009
                                • 333
                                #45
                                I ran mine in delta 33 knock off, went with x445 prop... man the boat flew! Did not have a GPS in it, but it was way better then with x64- I've tried before.
                                Temps are better (lower) then Castle-Neu. It does seems to be better compare to Castle-Neu considering the price and performance.
