NAMBA April Time Trial Monday 5th and Tuesday 6th 2021 Huntsville, Alabama
  • jaike5
    • Dec 2011
    • 561
    #31
    Congratulation's Don on the team work to achieve those times and speeds. Great head scratching !! Hope to get down there in November for some roundy round racing , as long as the boarders are open , and covid has gone away.
    Cheer's, Jay.
    • donhuff
      • Dec 2014
      • 561
      #32
      Terry. I thought about turning it off but I didn't think to take my laptop. And with the Atlanta race coming up, I didn't want to be down another esc. I got one wet at the February SOWEGA race and made copious amounts of smoke. So for the next race I'm having to use another one of my BLASTED MGM escs.
      I think that "next time" for a record try, I'm not going to take more props, I think that rather than going bigger on the prop, I'll just add more kv, and go down on prop diameter, because Martin said that it was pulling to the right a lot. More diameter means more prop walk! You should have heard what he told me about how he was making the SAW passes. Half way through our talk, I raised my hand and said, you do what you do, and I'll be over there in the pits turning the wrenches. I know when to keep my mouth shut!!!
      I would like to get the prop back down into the 1814-15 range and get to the speeds I am at now, and go up from there with pitch, until I run out of pitch, then go up to the 19 diameters. I have a 3050kv, 3180, and a 3300kv motors that are similar to the one I was running.............more head scratching ahead for sure.
      AmpDaddy
      don huff
      • donhuff
        • Dec 2014
        • 561
        #33
        Thanks for the congrat guys. I wish Martin was on here so you could give him some credit too. I would have been able to get a couple of the records by myself (I think), but with him doing the driving, that took a lot of pressure off of me and I could think more about rpm,props,amps, the mechanic side of things, that's where I'm at my best. All day long I was texting the family back home about the results. After getting the ltd cat records, I was ready to head home because that was all I really went after. I hadn't really planned to go to this event, but the day before the weather predictions were so good that I decided to go. My usual drivers Lamar and Brad couldn't be there, so I was reluctant to go. Boy was I relieved to see Martin was there, with him driving, it actually does become "easy" to do. No mater how good a driver you think you are, for oval records, I'll bet money he can better your times.
        AmpDaddy
        don huff
        • RaceMechaniX
          • Sep 2007
          • 2821
          #34
          Hats off to Don for an awesome records haul including one or two records I had previously. As much as I dislike the limited class rules Don has put in the effort to tweak these motors to really output noteworthy power. 300A is about double what the best stock AQ motor I used for time trials could output before smoking.
          The more offensive point is he had a hired gun drive the boat. C'mon Don, drive you own boats.
          See you guys in Atlanta.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • Peter A
            • Sep 2012
            • 1488
            #35
            I know that this "limited" debate has gone on for years. What is being achieved is wow, and well done to those who put in the time and effort, with a fair bit of driving skill to set the records.
            The only thing that can truly limit an electric class is the battery capacity, watt hours, or the size of the 'fuel tank'. With 10,000 mah max, the potential is always there to utilise all the power available. The only way to limit it is essentially a smaller fuel "tank", the battery. If you had a 5000 or 6000 mah limit would you see the same results? Perhaps if batteries can be obtained that will perform for speed and 2-lap. It does however bring an actual limit in oval racing.
            For our club P-ltd offshore class, we limited the motor size to 36 x 75, the hull length to 36" max, and batt capacity to 6000 mah. The whole point was to make sure we had an entry level class that can capture any RTR boats available (the Sonicwake fits, hence the 36"). One of the boats in our club was build from a not so great random glass hull, no stinger or trim tabs, just a stuffing tube straight out the back, TP 3640 2150 kv motor, Raider 150 esc, and it runs on turnigy HD 5000 mah batt and an M445. It is surprisingly competitive, and to be fair all the boats are fairly evenly matched for speed, so the racing means that whoever gets the best start and can hold the lead will usually win. It has broken the monopoly on winning that I had for sure, but it is more fun.
            Not trying to change what you guys are doing, just sharing what we are doing. It has to be about having fun doing this or it isn't worth doing is it?
            • donhuff
              • Dec 2014
              • 561
              #36
              "The more offensive point is he had a hired gun drive the boat. C'mon Don, drive you own boats."
              Really Tyler??? To quote the famous Dirty Harry "A MAN, has got to know his limitations" I know MOST of mine now that I'm old enough to accept the facts. And I DO know that I am not the best driver out there. At 67 years old, my reactions, vision, and hearing are all failing me. And yes, hearing is very important to controlling a raging monster that's right on the limits.
              Yes, I could have gotten a couple of those records on my own, but why? I'm not the type that thinks I'm the best at everything. What I am is a damn good mechanic. I can look at things and figure out how to make them faster, quicker, smoother, more reliable, etc,etc. I am not a "great" driver.....anymore. I like to watch top fuel drag racing, because it is about 90% the machine, yes the driver has a lot to do with it, but not as much as in other racing venues. I enjoy seeing what the crew chief can do with the machine, and I don't really care who the driver is, unless it's John Force---I hate that guy!
              Had my son Lamar been there, he would have done the driving. Had Martin nor Lamar, not been there, and you were there, I would have asked you, if you would drive for me, to positively get two to seven records. Would you be whining then??????? I'm not afraid to share a record. I can recognize talent when I see it. And you are one of the few who has it.
              And just so you know, a lot of this P-limited cheater motor hoopla bs is YOUR fault!!! Because you were the third person to tell me to my face that "there is only so much power that you can get out of a motor can that size" !!! Never ever tell a true hot rodder mechanic that, unless you want to get outrun.
              AmpDaddy
              don huff
              • Darin Jordan
                • 8335
                #37
                You guys are debating P-Ltd rules AGAIN? Good Grief, let it go!
                The class is doing great. Clubs that run it are doing great. It's as simple as it gets, and nobody who is actually running the class is complaining.
                And, some of the fastest racers in the country are still doing it with off-the-shelf motors, so this MYTH of a "motor of the month" club is just that...
                Seriously, if you don't like it, don't run it, but stop crapping on everyone else who does.
                Darin E. Jordan - Renton, WA
                • HUFFRACING
                  • Oct 2014
                  • 191
                  #38
                  I've been a member of the club for several years now... In fact, I just renewed my subscription!
                  Usually you get a stock AQ or SSS, but every once in awhile you get one of dem super dooper motors!!!
                  Later,
                  Lamar
                  --- Contact me for information on HUFFRACING modified Zenoah engines ---
                  --- Record setting performance at an affordable price! ---
                  • T.S.Davis
                    • 6221
                    #39
                    Don, how do you think my brat keeps ending up with fast boats? Know yer limits.
                    Noisy person
                    • fweasel
                      master of some
                      • Jul 2016
                      • 4285
                      #40
                      His mom?
                      • Darin Jordan
                        • 8335
                        #41
                        Ummm... Don... there IS only so much power you're going to get out of a motor of that size. You're finding that limit, but that doesn't make the statement any less true.
                        • admin
                          • Mar 2007
                          • 49
                          #42
                          Originally posted by fweasel
                          his mom?
                          haha, that was good.
                          Steven Vaccaro
                          • RaceMechaniX
                            • Sep 2007
                            • 2821
                            #43
                            All in good nature fun Don. I have to admit as well I will likely never drive a TT course as fast as Martin, Brian Buaas or Chris Grim, but do enjoy trying.
                            Guilty as charged! Ready for you next challenge?
                            Tyler Garrard
                            • Doug Smock
                              Moderator
                              • 5272
                              #44
                              MODEL BOAT RACER
                              IMPBA President
                              IMPBA 19887L CD
                              NAMBA 1169
                              • photohoward1
                                • 1610
                                #45
                                I kinda just want to be able to race oval again. I miss you guys.
