Herb Stewart Tunnel with Mystery Motor
  • properchopper
    rcgoatbuild@snotmail.com
    • 6953
    After doing OK ( one first, one second and the other three heats middle of pack plus one DNF) in AZ as a Spec boat, it was time to get ready for the "ZSP/WTS ?"
    [ Zoom-Splash-Plop/What's That Smell ? ] race , better known as SAW's. First test with smallish prop and a motor I've had sitting on the shelf for years . Trim angle was unchanged from the Spec setup, will adjust accordingly : And yes, It's a Stilletto cowl; will have smaller/lighter cowl fitted soon-
    camera shut off on this vid -
    " ZSP/WTS?" vid - no smell but ate the servo :
  • steveo
    • 1454
    motor looks to be a fegiao but for cars with the fins, i have a 7xl sittin on my shelf looks like someone drilled 4 holes in the top, yes?
    • properchopper
      • 6953
      Wow, that didn't take long ! Right you are & yup, I drilled holes in the endbell
      ( which unscrews) for better cooling & to let the water out & the Corrosion/X in after the inevitable dunking Since this is a SAW's application, I'm counting on air-cooling to do the trick since the runs are only a few seconds.
      • steveo
        • 1454
        the boat looked good till it took flight, do you know how fast it was and what wind is the motor? or is that the mystery?
        • properchopper
          • 6953
          You were right the first time; a 7XL. The drive was angled up too far for this motor (obviously ) - it was that way to loosen up the boat for the spec setup and I hadn't changed it- will do it for more testing happens. Just a trial run to check motor temps; will get some GPS readings as things progress; more prop & more speed coming
          • steveo
            • 1454
            hey if you want a back up motor, i can give you a good deal this thing has been sitting around with about an hour drive time
            • ron1950
              • 3024
              will the weight of that stieletto cowel make that much difference? it sure looks good
              • properchopper
                • 6953
                It weigs four oz. more than the VS-1 cowl that I'm going to use & the VS-1 cowl is much lower profile. For SAWs every little bit helps !
                • Jacked1
                  • Jun 2010
                  • 772
                  That is a quick tunnel! Good luck at the SAW's!
                  I used to run the DPI in my avatar without the cowel and it was less prone to blow overs since it stuck out and gave a little more surface to catch the air.
                  Makes me want to convert one of my old 3.5cc OS tunnels. I guess I do have 4 spare lower units. :D
                  Fleet: 55" Quad inline T600 Cigarette boat, Twin Mean Machine, Twin T600 47" mystery mono, 4082 Surge Crusher, 1717 8s Genesis, 4074 Villain, "mini mono", 52" Bonzi, Prather Funcruiser, 2 DPI 3.5cc tunnels, 5' Styrofoam recover barge
                  • cybercrxt
                    • 2909
                    Tony, It looked good. I would maybe take out a 1/2 degree in the drive. Looked to be going around 60ish. I like the look of that tunnel. Stilleto cowl looks real nice on it! Mike
                    • obrien
                      • Nov 2007
                      • 1264
                      How long have you had that hull? Herb did build some pretty good hulls. I have been trying to get ahold of his son but with no luck lately. That boat seems to be running pretty good.
                      • sailr
                        • Nov 2007
                        • 6924
                        Jeff, I have his son's phone number if you need it.
                        Mini Cat Racing USA
                        www.minicatracingusa.com
                        • properchopper
                          • 6953
                          I bought it as a bare hull from someone here on OSE right after Herb passed away. It's been sitting on the shelf 'till recently. For a big boat it did pretty well as a P-Spec rig, not exceedingly fasst but really stable. Will start tuning for SAWS very soon & will post progress.
