You can quite easily make your own... Do you have a soldering iron?
Cap banks - the pre-emptive answer
This is a sticky topic.
I'm looking for someone who has made them in the past and sold them here at OSE
thanks.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
What would be the best setup for extra Caps for 4S to 6S
The ESC has 4 built in 35v - 390uf already.
I have in the past added 4 extra 35v - 470uf caps.
I need to know if this is good, or is there a better way.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
Up to 5000uf additional caps wouldn't hurt ... to be on safe side and all. If you think thats a lot they are 470uf caps after all... but more of smaller caps are better (more efficient) than less of large ones.
A lot of people add (more or less) caps based on ESC though. Just make sure they are new and decent quality caps (Rubycon ZLH or ZL) and not the old/dodgy rubycon stock from Ebay... :P
What kind of ESC are you running?Comment
I run CC 240 Hydra's mostly on 2 & 4S thinking about a 6S setup also.
I have not had any problems this way in years.
Is this good enough or is there a better way?????
Larry, the 470uf caps would do just fine. Better than nothing should I say. I think 4 or 6 1000uf 35v would be better. That's what I use on most everything unless it's hv then I go up to 50v caps. I have actually picked up speed going from 6 1000uf caps to 10 1000uf caps on one of my saw boats. Not saying more is always better, but it was in this instance. I'm no expert as I learned about caps because of this thread, but this is what's been working for me.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Do you connect 6 - 1000's in Parallel or do you put any in series??Larry, the 470uf caps would do just fine. Better than nothing should I say. I think 4 or 6 1000uf 35v would be better. That's what I use on most everything unless it's hv then I go up to 50v caps. I have actually picked up speed going from 6 1000uf caps to 10 1000uf caps on one of my saw boats. Not saying more is always better, but it was in this instance. I'm no expert as I learned about caps because of this thread, but this is what's been working for me.
I get mine from some electronics place on eBay. I use rubycon or nichicon32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
That is good news..Larry, the 470uf caps would do just fine. Better than nothing should I say. I think 4 or 6 1000uf 35v would be better. That's what I use on most everything unless it's hv then I go up to 50v caps. I have actually picked up speed going from 6 1000uf caps to 10 1000uf caps on one of my saw boats. Not saying more is always better, but it was in this instance. I'm no expert as I learned about caps because of this thread, but this is what's been working for me.
does your esc run cooler with this setup ?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Well to be honest I've never checked before and after. I've always just added the cap bank on my builds and my customers builds. The only boat I have that doesn't have an added cap bank is my zelos. But that won't be long before I add one. Likely 4 1000uf per esc I'll add.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Do you know this from experience? I've run several castle escs without cap banks and they never failed. Brushless55 has one in the rigger I sold him. No extra caps. Works just fine. They are very sensitive to water. I epoxy coat every esc I run. Including the castle in his rigger.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
