Cap banks - the pre-emptive answer
This is a sticky topic.
  • Nikolas Andriop
    • Jun 2015
    • 73
    #316
    Hello
    I have an Apparition cat with TPPOWER 3640 2080KV at 6S for SAW and Seaking 120Amp
    I have made a cap bank with 5 pieces 1000μF 35V at series ....so i have 2500μF right???(Now i have made a 4 pieces at series 2200μF 35V to test)
    Another question what if i use just a single Cap at 4700μF 35V.Will that work???
    Thanks!!!
    • dmitry100
      • Mar 2015
      • 1264
      #317
      Nikolas: Read the entire thread... all the info you're asking about is all there. Especially if you look a few posts above....
      • Nikolas Andriop
        • Jun 2015
        • 73
        #318
        I all ready read the above post my friend but im asking for my case
        Im trying to learn....
        But thanks for your help!!!!!!
        • dmitry100
          • Mar 2015
          • 1264
          #319
          Ok, then no its not better to use those huge caps because they will recharge much slower than smaller ones.
          So make a cap bank consisting of smaller ones like around ~470uf 35v....
          • Nikolas Andriop
            • Jun 2015
            • 73
            #320
            How many caps do you thing sould I use???
            In series or parallel???
            Thanks so much!!!!!!
            • drwayne
              • May 2008
              • 2981
              #321
              Hi Nikolas
              Capacitors add together when parallel total = C1+C2+C3 ....
              resistors add in series .. total = R1+R+R3
              your photo shows capacitors in series ... where C1+C2+C3+C4 .. = total
              2500uf is enough, yes ... but the 1000uf are too big and energy hungry .. is much better with 330uf or 470uf to make 1500→2000uf total for the 120A on 6S
              Dmitry ..
              • dmitry100
                • Mar 2015
                • 1264
                #322
                drwayne: Is there any particular reason to have additional caps close to the ESC pcb? I see alot of people doing it, so was just wondering if theres a reason for it... versus the way you outline here in the thread.
                Also, if say I have space to solder additional caps onto the PCB (in parallel or series)... would that be a good idea, or would it be best to just add any additional ones on the leads instead? Can't imagine doing that would create any issues... or can it?
                If say I'm using a Lehner ... they are all D-Wind correct, So they would benefit most from a parallel/series cap setup compared to a typical parrallel setup for y winds?
                Do you think it would benefit to have a cap bank that has the best of both worlds-- as in... a row of larger caps in parallel for more capacitance and row(s) of parallel/series for quicker recharge / refresh?
                Best to use ZL rubycon's over ZLH?
                Thanks for your help!
                • drwayne
                  • May 2008
                  • 2981
                  #323
                  Hi
                  → Providing your wiring is a good conductor, cap baks can be anywhere betweenb nbbattery abnd esc .. if substandard..closer to esc is better
                  → Lehner are as per your order.. D or Y... or as you configure the 6 ports out rear their motors ..
                  → always have each capacitor 'set' with equal value acting across feed lines ( incoming red+black) or the weaker set will suffer and fail.. in moments, not minutes or hours ...
                  → buy the best available to your budget / availability ..
                  still not receiving email notifications of messages .. checked all the junk filters and OSE settings etc.
                  sorry for delay
                  W
                  • dmitry100
                    • Mar 2015
                    • 1264
                    #324
                    Thanks for the reply... much appreciated!
                    What email provider are you using?
                    • drwayne
                      • May 2008
                      • 2981
                      #325
                      < hidden >@chariot.net.au which is alias forwarding to my service provider @tpg.com.au
                      mailbox has @offshoreelectrics.com as allowed .. recently no incoming
                      • dmitry100
                        • Mar 2015
                        • 1264
                        #326
                        Have you checked your chariot email box settings to make sure you have whitelisted it there and that its not catching the spam filter?
                        I would look there first...
                        Seeing how these kinds of email "templates" of the forum are very commonly used-- it could have easily triggered a spam filter between those 2 email providers.
                        In addition to @offshoreelectrics.com , make sure you have oseforum@gmail.com too. It's also possible that these emails can be triggering a different "phishing" filter because the emails that this forum sends it pretends that it is passing from the email "oseforum@gmail.com" but it is in reality sent via offshoreelectrics forum server directly.
                        • dmitry100
                          • Mar 2015
                          • 1264
                          #327
                          Kind off topic... but is there any particular benefits ordering a Lehner in the 6 connector variant aside from being able to use it in star/triangle modes? Less resistance due to more contact between ESC phase leads?
                          • drwayne
                            • May 2008
                            • 2981
                            #328
                            The 6 pole option Lehner give you 2 different Kv ('Y'Kv x 1.72 = 'D'Kv) and Wye/Delta performance characteristics.
                            2 options for the price of one.
                            I think that's good value.
                            • dmitry100
                              • Mar 2015
                              • 1264
                              #329
                              DrWayne, for the sake of saving space due to the size of ESC and if I'm using an external cap bank with plenty of caps in series/parallel -- would it be OK to remove all the caps on the ESC's PCB ? or should I maybe leave at least some...
                                • 9488
                                #330
                                does someone make cap banks on OSE that I can use for my P Limited and Q setups ?
                                thanks
