So this does the same as the little piece of fuel line that some use ( ? )
Seal that stuffing tube with a Vacum plug !!
Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Fuel tubing works fine. I went to these for my wire drives and my .187 cable boats because silicone tubing was too big or to small for those applications. Searched today at auto part stores for the vinyl ones with no luck; hardware store had these for "screw tip protectors" $.11 to $.17 each.
Those are the bad boys I use for protecting the negative battery bullet on my lipo packs. Slide right over and fit nice. Loose enough to pull off but not to loose to fall off when handling. Cheap too! But its tough to find them for some of my packs that have the 8mm bullets.
John2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
So what would you guys recommend to seal a 5/16" tube (1/4" flexshaft)?- IMPBA Hall of Fame -
- IMPBA Hydro Technical Director -Comment
When I had to seal two of my wire-drive stuffing tubes, I ingeniously* used vacum plugs. Worked great ! Just sealed a .187 cable in my Cyberstorm the same way. Just punch a small hole in the end, slide on the stuffing tube for a nice seal
*It's hard to be humble when you're a Legend {In your own Shower}Comment
You can use small shrink wrap CAd to the stuffing tube then put your wire in and shrink it around it. Works well. I also use antenna caps but this is for smaller wire drive stuffing tubes.Comment
Double up the shrink tubing...just when you insert the wire after shrinking be careful and hit the hole....don't just jam it in there. Also a little extra grease up at that end on the wire as you slide it in. Glad to hear it is working well.Comment
