Seal that stuffing tube with a Vacum plug !!
  • properchopper
    • 6968
    When I had to seal two of my wire-drive stuffing tubes, I ingeniously* used vacum plugs. Worked great ! Just sealed a .187 cable in my Cyberstorm the same way. Just punch a small hole in the end, slide on the stuffing tube for a nice seal
    *It's hard to be humble when you're a Legend {In your own Shower}
  • tth
    • Apr 2008
    • 1510
    Sweet....I have been wondering how to convert one of my hydro's to wire without swapping out the stuffing tube. Good going there Tony....
    • Ub Hauled
      • Aug 2007
      • 3031
      LOL
      nice Tony!
      How did the testing go?
      • bonewar
        • Jan 2008
        • 549
        GEE WOW,
        That must have taken some thought power to sort that out.
        Bonewar
        SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
        • Jeff Wohlt
          • Jan 2008
          • 2716
          I use antenna caps for the smaller wire drives and work well. Usually the cable will begin to eat the rubber but will last for a while. The vac cap may hold up better.
          www.rcraceboat.com
          [email protected]
          • H2OCamel
            FAST ELECTRIC EVERYTHING
            • Oct 2007
            • 484
            Awesome tip thanks!
            "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3480
              Nice. Very nice!
              • ReddyWatts
                • 1711
                I like it!!!
                ReddyWatts fleet photo
                • simo71
                  • May 2010
                  • 74
                  What type of stores do you buy these from?
                  • properchopper
                    • 6968
                    Auto parts stores.
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2558
                      Great tip! And even if they do wear out, you can replace them for cheap! Do you usually punch a small hole? Or just slit the end?
                      • RandyatBBY
                        • Sep 2007
                        • 3915
                        Cool thought. Thanks
                        Randy
                        BBY Racing
                        • properchopper
                          • 6968
                          Oh, Sorry, you mean the VACUM PLUG
                          Just a small hole with the tip of an X-acto blade
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2558
                            Oh brother!!!!
                            I'm going to try the vacuum plug idea next time I remove the flex. Simple and functional.
                            I thought I was a genious one day and folded over the shrink tube into the stuffing tube. The theory was that it would act like a rotary lip seal. if the pressure is higher on the prop side, the folded lip would seal onto the flex shaft. Works good at first, but it splits after a few runs. The optimum would be the rotary type seal in the second photo.
                            • properchopper
                              • 6968
                              The vinyl plug works well for my wire drives which are "smooth". When I went to the auto parts store for bigger ones for the .187 shaft, all that was in stock was the rubber ones. One run on the rubber & it got worn. I found a vinyl one that fits in my parts drawer & just installed it-we'll see if the flex cable wears this one out.
                              The rotary seal you picture seems like a good idea - I'm going to see if I can find the right size & give that idea a try. Good thinking !
