I'm not saying Venoms stuff is great. We all know aftermarket is better. There are many people who have had good luck with the stock electronics. So when I ask about how to make the best of the stock equipment and get the answer "replace everything" that's not really that helpful, that's all I'm saying. Of course I'm going to run it stock to see how it goes, then upgrade what needs to be upgraded based on my needs and expectations. I respect that you have had lots of experience with this boat, I'm sure I'll be asking you about things later on, I was just looking for a few tips to get a starting point.
New EKOS owner here
Nevermind, ordered up a set of the wire drives. Have a few things to install before actually running it. How much gap do I need with the wire drives? Less than the flex shafts right? I've heard of the wire drives binding a little if there is an arc in your stuffing tube, true?Real men have shafts.Comment
Kos mods
I just reworked my kos and put batterys in sponsons and running seaking 60amp esc's, planning on putting in some feigo's but am undecided what ones to run, i want to have one boat that i can run for a bit without temp issues, and boy....she handles really great now, JUST WANTED TO SHAREComment
Still haven't run this thing, maybe next week. Got my wire drives in the mail, haven't put them in or anything yet.Real men have shafts.Comment
Nevermind, ordered up a set of the wire drives. Have a few things to install before actually running it. How much gap do I need with the wire drives? Less than the flex shafts right? I've heard of the wire drives binding a little if there is an arc in your stuffing tube, true?Comment
ALWAYS make a slight flat and make sure any couplers you use has 4 setscrews like mine. Otherwise the wire will bore the alum out and bye-bye drive. Also use blue thread locker on everything.Comment
Well I got the EKOS wet for the first time today, just testing it out. Started with 6S and 34mm props. The pond I ran it in is pretty small and barely had enough room to get the boat on a plane. Got the ESC's programmed and everything ran smooth. Threw on the 36mm props just to see how they were and what a difference! The boat wanted to jump out of the water. Again didn't have much room to get up to full speed but I know the boat works and will try to find a bigger place to run it.Real men have shafts.Comment
Got some pics, pretty basic. Like I said I just got it and have only run it once, didn't even get up to full throttle. Have done a couple mods: extra cooling lines, flex cable collers, 5.5 bullets, and wire drives (not installed yet). Found a place to try to run it the next day or two. Here's the pics:
With 6S what amount of timing is everyone else running? I have mine at 0 right now.Real men have shafts.Comment
Was doing some electronics tweaking on the bench today and I'm noticing that both motors don't start turning at the same time. The port motor starts right away and if I hold it at a low rpm the starboard motor won't turn. If I give it more throttle the stbd one kicks in. I'm concerned that one motor is working harder than the other. Is this a problem or something that only happens at low rpm?Real men have shafts.Comment
Think I got the motor thing worked out, I think one ESC had the timing set differently. It still does it in reverse though. Anyone run other than 0 degrees timing?Real men have shafts.Comment
