New EKOS owner here
  • dont slow down
    • Feb 2011
    • 120
    New EKOS owner here
    Picked up a EKOS last week and have been doing a lot of research before this thing even sees the water. I've read about the motors blowing up, the ESC's frying, cooling issues and have been doing what I can to prevent any mishaps when I start running this thing. I've already opened the rudder cooling port and tied some cooling lines into the originals with some Y fittings to get some more water flow. I've gone through all the screws and loctited them. I've ordered 2 of the Turnigy 3S 35C 5000 packs and am waiting for them to arrive. I will likely switch to my Spektrum radio before I run it as well. I'll be getting some collets to put on the shafts just in case the couplers come off. I've also put a small o-ring on all the cooling line fittings to keep them from coming off.
    My main question is: Has anyone had as many problems with the newer outrunner motors?
    As it is stock, what other issues do I need to address before running it in stock configuration?
    Thanks
    Real men have shafts.
  • Randy Willard
    • Oct 2010
    • 4
    Sounds like your doing the right stuff. The only problems I have had, is the servo mount glue breaking loose, and the radio quit working. Which the same thing happened to my brother's EKOS. Once we replaced the radios, and re glued the servo mounts, ours boats have been perfect.
    • LarrysDrifter
      Big Booty Daddy
      • May 2010
      • 3278
      Completely gut the hull and re-inforce it.Then,throw away all the stock electronics/motors/flex shafts/battery tray/rudder and mount,then re-build it with quality parts.
      • jamespl
        • 742
        That's ok if you have bottomless pockets. I was looking on the venom website at the v380 outrunners and it says under batter type 2-4 cells. I wander if it would work ok on 2x4 cell lipos?
        • dont slow down
          • Feb 2011
          • 120
          Thanks
          Blah blah blah, replace everything stock, aftermarket is better. Well the boat will still run with stock equipment right?
          The battery recommendations for the boat are only up to 11.1v (3S) packs (2 of them). The motors themselves are rated up to 5S voltage according to Venom, and the manual says the speed controls are rated up to 10.9v each. I've read that some people are running 2 4S packs and doing ok, but it's not rated for that much from Venom. So I guess if you swapped out ESC's you could bump up to 4S packs and the outrunner motors should be fine. I'm going to stick with 3S for now and see how it goes.
          I have another question, does anyone else's hull not have the metal tabs for the hatch magnets? My hatch doesn't attach to the hull at all. Venom says the magnets aren't supposed to hold the hatch on but the manual clearly states that the magnets should hold the hatch securely in place.
          Another question I have is what are these little green donut things that the ESC wires are wrapped around? Is it some sort of signal amplifier or something?
          • Diesel6401
            Memento Vivere
            • 4204
            - Don't rely on the magnets. Always use hatch tape.
            - Venom does not make anything of their own, unlike Aquacraft and Proboat. Venom re-brands and adds their lables to things. With that being said you esc is a Hobbywing Seaking v2 esc and it will take 4s without an issue. Venom just suggested running at a lower voltage I think because of all the issues they had on the first gen of ekos with the higher voltage which was actually a motor issue not a esc issue. The hull itself is a Dragon Hobby Hull, and should be re-inforced like mentioned above. This is your hull with a different paint job, also the hull itself is 32" not 34", venom just included the hardware for the extra 2" as other measure the bare hull itself. Here's the same hull http://www.hobbyking.com/hobbyking/s...dProduct=13774
            This http://www.venom-group.com/itemdesc.asp?ic=1398 is 99.9% the same as this http://www.hobbyhot.com/hobbywing-se...1-pr-1670.html the .01% difference is the stickers and venom soldered a ec3 connector on for you. With all that being said the green donut if a filter. The motors I think are Suppo's. At least I know the P1 mono 2000kv motor is a suppo. I had one and I compared it to my Hobbyking Turnigy Suppo outrunner and it was the same besides venoms motor mounting mod.
            - I do find it shocking that you said they mentioned running only 3s on this hull. That doesn't yield much unloaded rpm for a twin. 2700kv on 3s is only around 29k unloaded which would be great for a single motor, but twins like higher rpms. A 4s setup is more applicable to the stock setup. I have a feeling sense the first ekos was such a nightmare on 4s that they stepped all their ratings down for the second gen even though they used different motors. 1 think I would suggest is ordering some wire drives for your setup. I bet the venom 32mm props on 4s would rock and the 36mm on 3s. JMO of course. The hull is not a bad hull at all and with the outrunners they stuck in the hull it should work great for you. Just take your time, seems like your on the right track. I would like to STRESS that you should reinforce the hull, these China hulls are great for their value, but at higher speeds the can split at the seems. The first gen ekos (same hull) had a issue with this.
            *By the way I almost forgot to mention the most important thing: to OSE.
            - Diesel's Youtube
            - Diesel's Fleet
            • Dragboatdad
              • Jan 2011
              • 28
              Reinforcement
              I have an ekes too. I'm also new to this. I have upgraded everything(380 10xl 120esc wiredrives x442 props) Where exactly do they need to be reinforced. I don't thrash this boat but it is capable of speeds that could kite it.
              Thanks
              • dont slow down
                • Feb 2011
                • 120
                Where does it need to be reinforced? What do you use to do it? Who offers wire drive kits for this thing? Going to have to put the EKOS maiden voyage on hold till after I move later this month.
                • DyrtyByrd
                  • May 2010
                  • 146
                  you should reinforce the bottom of the hull inside the boat with carbon cloth or fiber glass (i prefer carbon) and use the appropriate epoxy to set the cloth. try to go as far foward as possible with the cloth under the front deck, and as far up on the sides of the hull as you can go make sure to get the epoxy nice and smooth (and not too thick) where you plan to mount your electronics. i think jeff wholt makes wire drives for this and ose sells them
                  • LarrysDrifter
                    Big Booty Daddy
                    • May 2010
                    • 3278
                    A good place to research this boat is the Venom RTR threads.Lots of information and build threads there.I said what I said in post #3 is because I have this boat and know all too well its weaknesses.I have a build thread in the Venom RTR section.
                    To James,I do not have bottomless pockets in any way.
                    To the original poster of this thread,there is no blah,blah,blah about aftermarket parts being better than factory. The fact is,MOST aftermarket parts are better than Venom puts in their hulls.Venom buys the cheapest parts and re badges them.Most of us have had the worst of luck with our EKOS,only to replace the parts with higher quality parts and got to go faster as well.Its very easy to be $1000 in the hole with this boat. Take the advise of others when they say it isnt worth it. Its a very cool looking boat,but thats where the positivity about it stops.
                    Others and myself included are more than happy to help you in any way with your build.
                    • dano1
                      • Dec 2010
                      • 403
                      ive got mine running good all stock with the exceptions of a rudder kit and props, im thinking of upgrading the motors in mine....its a slow boat but so far dependable and fun to run, good luck on your quest
                      • Dragboatdad
                        • Jan 2011
                        • 28
                        What rudder kit did you get?
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          I make the wire drives and couplers to fit the factory set up. Have sold hundreds all over the world.
                          www.rcraceboat.com
                          [email protected]
                          • dano1
                            • Dec 2010
                            • 403
                            Originally posted by dragboatdad
                            what rudder kit did you get?
                            kit was from kintec, break away rudder, sorry i do not have the link, purchaced the boat with the rudder kit, but i think its in the venom section on there site
                            • forescott
                              Hopelessly Addicted to RC
                              • 2686
                              Only issues I had was the motors. It would be nice to get some feedback on the new outrunners. I replaced mine with feigao 9xl's. But I had the crappy old green inrunners.
